I have no ingress for over 1 month. Only egress.
I’m running the node on Qnap and have had 2-3 restarts because of QNAP Firmware upgrades.
Is this normal?
Is this normal?
Hello @matsmats,
If your storagenode is two versions behind the current version (1.31.2), it will not have any ingress.
Please, update your storagenode: Software Updates - Node Operator and configure automatic updates: Software Updates - Node Operator
Thanks for the quick reply.
I’m already running Watchtower, but it looks like its not running properly giving “Waiting for running update to be finished…” in the console.
I removed and added the Watchtower docker image with the correct cmd line via ssh and it’s not returning the console info message anymore.
Should I wait and see if the Node is updated, or should I do a manual update of the Node docker image?
You can wait (12h-72h) until it automatically update the storagenode or can update it manually. The next update should happen automatically.
Thanks! I’ll wait and see if the storagenode is updated automatically to verify the update process is working.
Just make sure that you do not have more than one instance of watchtower running
Thanks for the follow up.
I noticed I started the storagenode with a different name than the one I specified in watchtower.
So I started a new docker and everything is up and running now.
I’ll monitor the update process now so I’m sure it’s working.
Thanks again
Watchtower is working perfectly
