most likely you have some sort of software / firewall / router which blocks the incoming data.
maybe you used a ddns and the ip changed, but then i think egress should also stop
Storj satellites stop uploading data to nodes that are two versions behind and nodes that are three versions behind are not considered online, so if you ever get to that point your node will start losing online score and will eventually be disqualified.
good call totally missed that because he wrote new nodes.
@gael
there was a new update a few days ago, and thus version 1.36 is now outdated and will not be getting any ingress until updated to the new version.
yes watchtower should update, there is a new version on the way also, should update again in like a week, so check that it does update then, if it doesn’t you will need to fix it.
you can ofc take a look at it now if you want, personally i would just maybe go over watchtowers settings and then just wait and see what happens in the next week
might take a day or two before watchtower does update.
maybe that was the issue, not sure how you managed to end up with an old version.
@littleskunk maybe a new node or watchtower should check version or attempt to update when running for the first time.
