Hello everyone, I have three Storj nodes running for a year, and for the past few days, I’ve been receiving alert emails saying that my nodes are offline and indeed, my online percentage is dropping, but not on all satellites. I’ve checked that the correct ports are open on my router, that my DNS address is correct and properly resolved, and that my public IP hasn’t changed. In your opinion, where could the problem be coming from? Below is a log capture filtering on the ERROR tag :
2025-03-18T22:51:29Z ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "TO2MTWXX2O45OTU6G7W2UHCZEJOKUAWYPVCWZG42MLYYCH434WYQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 709376, "Remote Address": "156.146.43.228:39894", "error": "manager closed: read tcp 172.17.0.4:28967->156.146.43.228:39894: read: connection timed out", "errorVerbose": "manager closed: read tcp 172.17.0.4:28967->156.146.43.228:39894: read: connection timed out\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:211\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230"}
2025-03-18T22:51:39Z ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "TO2MTWXX2O45OTU6G7W2UHCZEJOKUAWYPVCWZG42MLYYCH434WYQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 709376, "Remote Address": "79.127.201.218:43656", "error": "manager closed: read tcp 172.17.0.4:28967->79.127.201.218:43656: read: connection timed out", "errorVerbose": "manager closed: read tcp 172.17.0.4:28967->79.127.201.218:43656: read: connection timed out\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:211\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230"}
2025-03-18T22:56:14Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 12, "error": "ping satellite: check-in network: failed to resolve IP from address: washu59.duckdns.org:28968, err: lookup washu59.duckdns.org on 10.103.0.10:53: read udp 10.101.3.192:37892->10.103.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: washu59.duckdns.org:28968, err: lookup washu59.duckdns.org on 10.103.0.10:53: read udp 10.101.3.192:37892->10.103.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:163\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
