Node count drop, is it because of Chapter11 thing
Hello everyone,
is this drop in network size normal (active node count dropping)?
“There are 31,915 active nodes, -946 during the last day” (storjnet.info)
Are they gracefully exiting ?
My active nodes ingress is breaking records at the same time.
What do you think? is it something temporary or is the game over?
I dont know, less nodes more data for us, that here.
May be someone have problems with electricity. Or lot of decided that they more not participate, it everyone’s own chois.
I also see 1.25-1.5x traffic
Depends on who is running away faster, SNOs or customers.
It’s sad to see some nodes leave: but it is a good time to sell used HDDs. Many SNOs who have been coasting may be deciding if they want stay or go. Nodes need so little maintenance I bet some SNOs forget they’re running if they don’t get any offline-emails.
You’re right that other nodes may see more repair traffic in the coming months. At least we know the repair process is working properly :wink:
I suggest everyone reads this thread with this playing in the background.
What i see it is Ingres not repeair ingress yet.
I did some reasearch on this yesterday. About 1000 nodes have gone offline over the weekend. They didn’t call GE. The total space they have been holding was 200 TB. It looked like mostly new nodes maybe as a preparation for scaling up.
That looks more like the usual start of the month backup tasks. I see these spikes since a few months now.
The repair system is not under stress right now.
Here is the even better news. Customers keep growing with only one except. Storj select has its peak usage mid summer and will now decline a bit. That has to do with the usage pattern of the customer. If we filter that out than all 3 satellites keep growing. Very slowly but still great to see in the current situation.
If I want to move to bigger drive, what is best solusion to not stress repair?
usualy i go offline and copy to new node.
but it 4tb will get 1-2 days. then repeir will start.
This is on storj, indicate of how documentation is lacking, normally, you would need about 10 minutes offline at most.
P/s: oops, take back what I said How do I migrate my node to a new device? - Storj Docs, personally never read that, so..
First migrate to hashstore and once that is done use rsync. It works really great with hashstore.
I usually do 4 runs.
First rsync will take days.
Second rsync will take minutes maybe an hour or so.
A bit unessesary but I give it a third pass to get down to seconds.
Shutdown the node.
One final pass that should take just seconds at this point.
Double check that the node is down and disable any cronjob or service file that might start it on reboot.
Start the new node in the new location. Also double check that service file is in place to restart it on reboot.
It still is a few minutes of downtime but mainly because I want to make sure I don’t end up with 2 active nodes that would get disqualified after some time.
RTFM :slight_smile: Much less than an hour offline is enough. If you are on ZFS, even easier and faster using snapshots.
Yeah if you do the rsync your offline time is short.
I think I migrated a node between drives which was mostly hashstore and it was a few times faster than the old micro blobs.
But why if we lost almost 2400 nodes this month, system should worry about it?
I feel like it will be good to make now more repeair, and if some SNO will go away with Door Bang, it will be not mediate big stress.
Also Stat show that there is more nodes are gone
Just looks like some operators already producing new nodes as you see on picture from stats, in case of /24 will go. each day +300, +150, +288, +133, +109
So /24 rule should not go away without something that will compensate that. people already preparing. that’s why people go very nervous when we start to speak about first 500gb free rule. Storj could implement something other instead of that.
But i can also be wrong, as i dont see is this some old nodes go back online or it is new nodes. So it worth to check, to not make some conspiracy theory.
simple solution to that, just disable all the nodes that are recently created. People are already trying to abuse the system that we don’t know if it’s gonna be implemented. This tells you that nodes creation must be stopped, and nodes recently created 1-2 weeks old should be disabled/disqualified on purpose
I dont see a problem here, just need instead of price reduction make first 500gb or some X Gb not paid, this will solve problem that people make lot of small nodes.
it won’t solve the problem, the only thing it will solve is that they won’t get paid for first 500GB, but after their node reaches 1TB they will get paid for that 500GB, which means people will still make new nodes, and the more nodes there is on the network, the less data there will be on each node, meaning you will get paid less and less every second, beacuse the data still will shrink, even if you have 10TB of data, they will get no money, but you will get less data. Which means it will affect everyone and this idea of yours is bad, I said it before.
they made and making 10-20 nodes on one 20tb hdd this mean each node 2tb or less to fillup fast. each node in separate /24. this rule will prevent it very easili
as I said before, the creation of new nodes should be disabled, there are way too many nodes on the network already. And disqualify all those nodes that were created in the last 1-2 weeks, these are most likely abusers that want to create as much nodes as possible before the 24 rule is turned off.
why it is bad, you prefer 20-25% reduction of each tb paid?
at leas my idea fixing discount, and when nodes go full we all will make more money.
why we prevent normal operators from creating nodes, to prevent abusers?
