Node crashed today and doesn‘t start again
Today in the morning my monitoring started throwing warnings that my StorJ Node keeps restarting. It‘s the first time after over a year of the node running.
The log:
storj-storagenode-1  | 2025-07-31 10:41:12,791 INFO RPC interface 'supervisor' initialized
storj-storagenode-1  | 2025-07-31 10:41:12,792 INFO supervisord started with pid 1
storj-storagenode-1  | 2025-07-31 10:41:13,794 INFO spawned: 'processes-exit-eventlistener' with pid 43
storj-storagenode-1  | 2025-07-31 10:41:13,796 INFO spawned: 'storagenode' with pid 44
storj-storagenode-1  | supervisor: couldn't exec /app/bin/storagenode: ENOEXEC
storj-storagenode-1  | supervisor: child process was not spawned
storj-storagenode-1  | 2025-07-31 10:41:13,818 WARN exited: storagenode (exit status 127; not expected)
storj-storagenode-1  | 2025-07-31 10:41:14,820 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
storj-storagenode-1  | 2025-07-31 10:41:14,821 INFO spawned: 'storagenode' with pid 45
storj-storagenode-1  | 2025-07-31 10:41:14,838 WARN exited: storagenode (exit status 127; not expected)
storj-storagenode-1  | 2025-07-31 10:41:16,841 INFO spawned: 'storagenode' with pid 46
storj-storagenode-1  | 2025-07-31 10:41:16,858 WARN exited: storagenode (exit status 127; not expected)
storj-storagenode-1  | 2025-07-31 10:41:19,863 INFO spawned: 'storagenode' with pid 47
storj-storagenode-1  | 2025-07-31 10:41:19,878 WARN exited: storagenode (exit status 127; not expected)
storj-storagenode-1  | 2025-07-31 10:41:20,880 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
storj-storagenode-1  | 2025-07-31 10:41:22,883 WARN received SIGQUIT indicating exit request
storj-storagenode-1  | 2025-07-31 10:41:22,883 INFO waiting for processes-exit-eventlistener to die
storj-storagenode-1  | 2025-07-31 10:41:24,885 WARN stopped: processes-exit-eventlistener (terminated by SIGTERM)
storj-storagenode-1 exited with code 0
I already tried deleting the binaries and the whole bin folder. It re-downloads everything and crashes again like above. My node ran great and I haven‘t touched anything, so I‘m totally out of ideas. Suspension time is ticking.
Edit: It‘s running as a Docker container on a Synology Diskstation. x86_64 platform.
Edit2:
I checked the *.db files with sqlite3. The ones in the /config/storage folder are all okay. The revocations.db seems to be no sqlite3 database.
After all those restarts the error changed:
storj-storagenode-1  | 2025-07-31 12:28:06,479 INFO RPC interface 'supervisor' initialized
storj-storagenode-1  | 2025-07-31 12:28:06,480 INFO supervisord started with pid 1
storj-storagenode-1  | 2025-07-31 12:28:07,482 INFO spawned: 'processes-exit-eventlistener' with pid 46
storj-storagenode-1  | 2025-07-31 12:28:07,485 INFO spawned: 'storagenode' with pid 47
storj-storagenode-1  | 2025-07-31 12:28:07,506 WARN exited: storagenode (terminated by SIGSEGV; not expected)
storj-storagenode-1  | 2025-07-31 12:28:08,508 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
storj-storagenode-1  | 2025-07-31 12:28:08,509 INFO spawned: 'storagenode' with pid 48
storj-storagenode-1  | 2025-07-31 12:28:08,524 WARN exited: storagenode (terminated by SIGSEGV; not expected)
storj-storagenode-1  | 2025-07-31 12:28:10,528 INFO spawned: 'storagenode' with pid 49
storj-storagenode-1  | 2025-07-31 12:28:10,543 WARN exited: storagenode (terminated by SIGSEGV; not expected)
storj-storagenode-1  | 2025-07-31 12:28:13,547 INFO spawned: 'storagenode' with pid 50
storj-storagenode-1  | 2025-07-31 12:28:13,561 WARN exited: storagenode (terminated by SIGSEGV; not expected)
storj-storagenode-1  | 2025-07-31 12:28:14,563 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
storj-storagenode-1  | 2025-07-31 12:28:16,565 WARN received SIGQUIT indicating exit request
storj-storagenode-1  | 2025-07-31 12:28:16,565 INFO waiting for processes-exit-eventlistener to die
storj-storagenode-1  | 2025-07-31 12:28:18,567 WARN stopped: processes-exit-eventlistener (terminated by SIGTERM)
From what I found online I tried renaming the revocations.db and the trust-cache.json so the node recreates them. Still no change.
If the data directory of the node is mounted with noexec, try mounting it without that parameter.
I‘m using normal bind mounts without any additional parameters.
I found the issue. Dumb past me set a quota on the storage that was reached. I removed it and now it works again.
Thanks for the help!
This should not be possible. Node always leaves a buffer of a few GB. Or did you set a quota after the fact, lower than actually used space? And DSM let you do that?!
@SplashmasterBee Thanks for the good read, I was about to add a quota to mine and now I will hold off and see if the size I told the Storj node to use, if it stops there.
