Hi,
running a docker node on ubuntu 18.04
last piecestore downloaded was on 2019-12-02
ip/port setup hasnt changed
tried restarting the node
any suggestions?
Hi,
any suggestions?
Hi ccc1 and welcome to the Forum
Please give us a bit more informations and post the output from:
docker logs --tail 20 storagenode
I would double check to make sure nothing has changed. Are you running ddns does the public ip need to be changed did ddns expire do you need to update it…etc
2019-12-10T17:37:34.351Z INFO Configuration loaded from: /app/config/config.yaml
2019-12-10T17:37:34.403Z WARN Operator email address isn’t specified.
2019-12-10T17:37:34.403Z INFO operator wallet: 0xblabla
2019-12-10T17:37:35.141Z INFO version running on version v0.26.2
2019-12-10T17:37:35.249Z INFO db.migration Database Version {“version”: 25}
2019-12-10T17:37:35.288Z INFO Node 1U7RuvLUVCSMikmzwnVqoZzVHcWehRZgjAe3CPVKJwahPzPPUb started
2019-12-10T17:37:35.288Z INFO Public server started on [::]:28967
2019-12-10T17:37:35.288Z INFO Private server started on 127.0.0.1:7778
2019-12-10T17:37:35.289Z INFO contact:chore Storagenode contact chore starting up
2019-12-10T17:37:35.307Z INFO bandwidth Performing bandwidth usage rollups
2019-12-10T17:37:35.439Z INFO version running on version v0.26.2
2019-12-10T17:37:37.003Z INFO piecestore:monitor Remaining Bandwidth {“bytes”: 98998942001152}
2019-12-10T17:52:36.145Z INFO version running on version v0.26.2
2019-12-10T18:07:35.844Z INFO version running on version v0.26.2
2019-12-10T18:22:35.875Z INFO version running on version v0.26.2
Had a similar problem on my Node with same log.
My ddns expired and does not update / response.
Did you already checked it?
May @deathlessdd already found your Problem
oh man, now I feel silly. thanks for the help @Solu and @deathlessdd !
Np… u’re welcome
No problem glad I could help.
