On some of my node running with no disruption since 5-6 days I’ve seen that uptime is just if 7 hours instead 169 hours like other node on same physical machine:
What could be the reason ?
How I can check it ?
thx
thx
It could be that 7h 55m ago your node got updated to 1.85.1
Node update or fatal error. Check the logs.
Well. There’s maybe some disruptions that you aren’t aware of. A quick restart?
Windows update? For 20chars
Logs are in the storagenode.log in the istallation folder. Not the data drive.
