Node desqualified and planned downtime
Hello everyone!
I have two questions that i would like to ask:
I have a node for some time and since it is almost full I decided to get a new one running. In the process I mistakenly pointed it to the same identify of the first node and it run for a couple of minutes before I removed the docker container. As a result (?) in a couple of hours my first node was disqualified on one satellite. Audit on that satellite went from 100% to 54%. How can I check exactly what was the cause of the failing audits and disqualification in case it was not related to my error while running a second node?
Second question is about uptime. I will have to move my hardware to a new data center soon and I fear that it will take more than 5 hours. There’s several posts saying that at the moment that wont be an issue but I would like to ask if that’s still the case.
Thank you!
Hello @lordsam and welcome to the forum.
Sorry to hear that :confused:
I’m surprised running a node just for 2 minutes with the wrong identity can disqualify it though. Having a node configured with the wrong identity can disqualify it fast, but not that fast I believe.
You should check your logs:
And search for lines that contain both “audit” (or “repair”) and “failed”.
On linux this can be achieved like so:
docker logs YOUR_NODE_NAME 2>&1 | grep -E "GET_AUDIT|GET_REPAIR" | grep failed
You have way more than 5 hours before getting suspended:
Thank you for your reply!
When I said a couple of minutes I did not mean exactly 2. Looking at logs it was around 10 minutes, but I run/delete several times so I can not be sure.
Anyway, grep’ing the first node logs I don’t have anything matching “audit” (or “repair”) and “failed”.
Anything more I can check? I just want to be sure this was not caused by something else that I did not notice.
I would expect the second node, with the same identity but no data, would be the one failing audits. Please check that log if you still have it.
Apparently those logs are removed when the container is destroyed.
Yes that’s how docker works unfortunately :confused:
