Hello,
Actually I’m running some 10 nodes with different public IP running on docker on same physical server each on different HDD of 14TB, since I have some nodes full and some other with 10-15% used I was thinking to move on big RAID5 configuration with 11 HDDs; using this configuration I can assign more space on node that need space and reduce the space allocation for the others.
What are the pro and cons ?
You’ll be adding redundancy the network doesn’t need, reduce the overall space you can be paid for, and make any IO issues worse (as RAID5 is one of the lowest-performance configs).
But yes you’ll gain some flexibility in how your nodes use space, and you’ll be much less likely to have a storage failure that would cause you to have to restart a node from scratch.
I think you’re better off running one-node-per-HDD until the HDD fails, and trying to get paid for every spare bit of space (instead of using some for resiliency).
@Alexey what is the guidance on this? Ok or not ok? If it’s now OK I can fire up 17 VPN connection and host 25 nodes on one server today.
It’s not ok, and you know this. This is evading the protection rule for nodes selection from each /24 to do not store the pieces of the same segment in the same physical location.
@brizio71 if your server would go down, the network would have a higher risk of lost or unrecoverable segment, and this could result in network shutdown, because the lost data = the lost customer = the lost trust = no payments = no payouts to anyone.
At best, the payouts will be cut even further, making the bypass uneconomical. Do you really want either of these options?
Regarding the topic, using a one disk per node is a best choice usually, but since you increase the risk of loss or made the segment inaccessible by bypassing a /24 limit, I would suggest to use a redundant setup for your hardware, including, but not limited to disks, the server itself, the redundant power supply or at least a managed UPS, the redundant internet connection, so using multiple ISPs, not VPNs, etc.
besides you shouldn’t be running one physical server with multiple IPs per the terms of service…
… also the maximum practical node size is around 18 or 20TB. If you start building a monster array it will be larger than what a single storj node can handle.
One node per drive gets you the best performance because the workload is so random I/O intensive.
8 posts were split to a new topic: Using multiple IPs on the same physical service
A post was merged into an existing topic: Using multiple IPs on the same physical service
