Node Disqualified on EU1 Satellite
Hi,
I just received and email saying that my node has been disqualified just on EU1 satellite, how can be possible just for one node and not for all others ? Looking my dashboard, I can’t understand the reason; I had some downtime but not so huge for a disqualification;
All satellites and nodes are independent. Each satellite audits pieces of their customers data, so the node can be disqualified by each satellite independently.
Please make sure that you received a disqualification message and not suspension, however, the audit score is definitely lower than 100%. This is a result of failed audits, and you need to figure out what’s the reason using the guide above to do not repeat this problem again with the next node.
