my node was running since 30/03/2020 with 99.9 % uptime (e.g for saltlake) and today around 10:00 UTC +1 the node shows up that it wanted to be upgraded from 0.35.3 to 1.0.1
since then my node dont shows up anymore
the last information i got in the logs was:
INFO Stop shutdown request recieved.
how can i bring back my node working?
it dont even shows the dashbord anymore
i have already tried restartig the whole server -->nothing
i treid to run the storagenode.exe manually over the CMD
with storagenode.exe run --> nothing happens
tired to start the storagenodeupdater over cmd with
storagenode-updater.exe run–>nothing happens
then i tried this thread Storj service won't restart after auto update (GUI)
then i finally started the storjnode service over the taskmanager and it brings back the gui but i still dont have a working node and the Last contacttime is still rising
now i got a warning in the Logs that More space is used than allocated( i allocated 600 GB to my node while my drive has 1000GB in Total and my last information around 9:00 in the moring was that ~35 gb are free on my node
what should i do?
btw i caht show you the logfiles from the node updater because i cant send more than 2 links in the post (and there are quite a lot of them in it)
Hi hafenhuhn, welcome to the forum. Sorry you’re having trouble. Seeing the storagenode logs will be important for troubleshooting. If you can paste the first 20 lines of your log file and put three backticks (it’s the ~ combo key) plus “text” above the pasted text and three backticks below the pasted logs, I think the forum will ignore the hyperlinks as it will now consider it pre-formatted.
```text
Paste logs here
If that doesn’t work, just manually remove the http part of the url. Only the first 20 lines should be needed to get started.
2020-04-02T14:12:51.560+0200 INFO Start downloading https://github.com/storj/storj/releases/download/v1.0.1/storagenode-updater_windows_amd64.exe.zip to C:\Windows\TEMP\storagenode-updater785503249
2020-04-02T14:13:02.051+0200 INFO Finished downloading https://github.com/storj/storj/releases/download/v1.0.1/storagenode-updater_windows_amd64.exe.zip to C:\Windows\TEMP\storagenode-updater785503249
2020-04-02T14:13:05.002+0200 INFO Restarting service storagenode-updater
2020-04-02T14:13:05.506+0200 INFO Interrogate request received.
2020-04-02T14:13:05.617+0200 INFO Stop/Shutdown request received.
2020-04-02T14:13:25.760+0200 ERROR Error updating storagenode-updater: Unable to restart service:
C:\Windows\system32>net stop storagenode-updater && net start storagenode-updater
The Storj V3 Storage Node Updater service could not be stopped.
The service is starting or stopping. Please try again later.
2020-04-02T16:13:16.384+0200 INFO Configuration loaded from: C:\Program Files\Storj\Storage Node\config.yaml
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: server.address
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: operator.email
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: storage.path
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: server.private-address
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: operator.wallet
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: storage.allocated-bandwidth
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: storage.allocated-disk-space
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: server.debug-log-traffic
2020-04-02T16:13:16.462+0200 INFO Invalid configuration file key: contact.external-address
2020-04-02T16:13:24.583+0200 INFO Downloading versions from https://version.storj.io
