This is a Windows GUI install.
I can no longer start my Node. I checked for malformed databases and had 3, heldamount.db, piece_expiration.db, and storage_usage.db, but after repairing them still nothing. I doubled checked the databases and then to test I removed all databases and tried letting the Node rebuild them, then after that failed I restored the databases. Thinking it might be a disk issue I did a checkdisk and that came back clean. Trying to manually start the service gives a “Error 1067: The process terminated unexpectedly” I am out of ideas.
This is what I am seeing my log file, but I am at a lost as to what it means.
2023-10-11T12:18:32-05:00 FATAL Unrecoverable error {“error”: “Error creating tables for master database on storagenode: migrate: v32: table paystubs already exists\n\tstorj.io/storj/private/migrate.(*Migration).Run:209\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:370\n\tmain.cmdRun:95\n\tmain.newRunCmd.func1:32\n\tstorj.io/private/process.cleanup.func1.4:398\n\tstorj.io/private/process.cleanup.func1:416\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomOptions:112\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:78\n\tstorj.io/private/process.ExecWithCustomConfig:73\n\tstorj.io/private/process.Exec:63\n\tmain.(*service).Execute.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”, “errorVerbose”: “Error creating tables for master database on storagenode: migrate: v32: table paystubs already exists\n\tstorj.io/storj/private/migrate.(*Migration).Run:209\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).MigrateToLatest:370\n\tmain.cmdRun:95\n\tmain.newRunCmd.func1:32\n\tstorj.io/private/process.cleanup.func1.4:398\n\tstorj.io/private/process.cleanup.func1:416\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomOptions:112\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:78\n\tstorj.io/private/process.ExecWithCustomConfig:73\n\tstorj.io/private/process.Exec:63\n\tmain.(*service).Execute.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n\tmain.cmdRun:97\n\tmain.newRunCmd.func1:32\n\tstorj.io/private/process.cleanup.func1.4:398\n\tstorj.io/private/process.cleanup.func1:416\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomOptions:112\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:78\n\tstorj.io/private/process.ExecWithCustomConfig:73\n\tstorj.io/private/process.Exec:63\n\tmain.(*service).Execute.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
