Node fails to start - Error 1067: the process terminated unexpectedly
After rebooting my pc (after stopping the storj services). one node failed to start - Error 1067: the process terminated unexpectedly. I tried the recommended deleting the cash-trusted.json (can remember the correct name) and running a sfc disk (no error).
What to try next?
Hello @mdmeyerpfa,
Welcome back!
Please provide 20 last lines from your storagnode’s logs.
2026-03-05T20:50:55-06:00 INFO Configuration loaded {“Location”: “C:\Program Files\Storj1\Storage Node\config.yaml”}
2026-03-05T20:50:55-06:00 INFO Anonymized tracing enabled
2026-03-05T20:50:55-06:00 ERROR failure during run {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T20:50:55-06:00 FATAL Unrecoverable error {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T20:54:10-06:00 INFO Configuration loaded {“Location”: “C:\Program Files\Storj1\Storage Node\config.yaml”}
2026-03-05T20:54:10-06:00 INFO Anonymized tracing enabled
2026-03-05T20:54:10-06:00 ERROR failure during run {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T20:54:10-06:00 FATAL Unrecoverable error {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T20:58:02-06:00 INFO Configuration loaded {“Location”: “C:\Program Files\Storj1\Storage Node\config.yaml”}
2026-03-05T20:58:02-06:00 INFO Anonymized tracing enabled
2026-03-05T20:58:02-06:00 ERROR failure during run {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T20:58:02-06:00 FATAL Unrecoverable error {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T21:08:01-06:00 INFO Configuration loaded {“Location”: “C:\Program Files\Storj1\Storage Node\config.yaml”}
2026-03-05T21:08:01-06:00 INFO Anonymized tracing enabled
2026-03-05T21:08:01-06:00 ERROR failure during run {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T21:08:01-06:00 FATAL Unrecoverable error {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T21:23:25-06:00 INFO Configuration loaded {“Location”: “C:\Program Files\Storj1\Storage Node\config.yaml”}
2026-03-05T21:23:25-06:00 INFO Anonymized tracing enabled
2026-03-05T21:23:25-06:00 ERROR failure during run {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-05T21:23:25-06:00 FATAL Unrecoverable error {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-06T12:21:19-06:00 INFO Configuration loaded {“Location”: “C:\Program Files\Storj1\Storage Node\config.yaml”}
2026-03-06T12:21:19-06:00 INFO Anonymized tracing enabled
2026-03-06T12:21:19-06:00 ERROR failure during run {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
2026-03-06T12:21:19-06:00 FATAL Unrecoverable error {“error”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”, “errorVerbose”: “Failed to load identity: file or directory not found: open Z:\Identity\identity.cert: The system cannot find the path specified.\n\tstorj.io/common/identity.Config.Load:326\n\tmain.cmdRun:56\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93\n\tmain.cmdRun:58\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:80\n\tstorj.io/common/process.ExecWithCustomConfig:75\n\tstorj.io/common/process.Exec:65\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:93”}
check where the folder with the identity is, the node can’t find it, maybe the disk letter has changed?
The disk letter has not changed. This is node 2 of a 4 node setup using multinode tool. All the other nodes are working fine. I tried using the multinode tool to repair the node data but it still fails with identity not found.
Z:\Identity\identity.cert is a text file. So it should be easy to check if it exists and is not damaged. Did you?
it does exist and appears to be ok.
Well, then it wasn’t at the time node attempted to reach it. What is Z? Mountable filesystem? Was it mounted at node start? Does the service user has permissions to read it?
the Z drive is a 12TB disk that was added to the PC for storage. The node was added to the drive in Sep 2024 and was working fine until the reboot a few days ago. This is Windows 11. I don’t think it is a mountable file system but I’m not sure as I would think it would normally just be assigned the next available drive letter. So I don’t know. It only has 800GB of Storj files so I’m ready to give up as I’m stumped.
If you start node now - does it start?
If so, you have a race at boot between node starting and disk mounting.
If not - post the new log because now the issue would not be missing identity file as you have validated above that file is present.
Either it’s absent or you provided a wrong path in your config.yaml or the storagenode service doesn’t have permissions to read it.
For the permissions issue I would like to suggest to update the owner of all node’s folders to SYSTEM, you should do it recursively, you also need to provide it write, read, delete permissions to be operational.
this is from the config.yaml file:
path to the certificate chain for this identity
identity.cert-path: Z:\Identity\identity.cert
path to the private key for this identity
identity.key-path: Z:\Identity\identity.key
I also updated the folder (and subfolders all thought there are none) owner to system.
Still same error
Thanks all for your suggestions. Time to move on. My other nodes are doing fine.
Why are you soliciting suggestions if you had no interests in getting to the bottom of this?
It’s not black magic.There are exactly four possibilities. Check each one individually and you will find an answer.
  • file not readable by the user running the node.
  • file not readable by the time node reads it
  • wrong path
  • Corrupted filesystem.
I have also asked you a question above that you ignored. If it wasn’t important I would not waste my time asking, would I?
Understand: threads like this exist to identify the root cause and help future readers. Quitting halfway through without closure defeats that purpose. Forum is not a personal helpdesk.
Found it. The path was wrong. I moved the identify folder to immediately below the Z: entry. It now works.
The original entry only had part of the path.
