Hello
I have the node for 2 months and I had no problems, but yesterday the pc was blocked and when I restarted the node it was offline and after 12 hours it is still offline. How can I activate it again?
Hi everyone,
I don’t know if I am the only one but for me is not working v1.9.5
I can see all my data on the desktop but the node is offline all the time, any idea to help
I did donwload the new ver on:
And then uninstall the old ver 1.6.4 after that did a clean instalation of :
storagenode_windows_amd64.msi.zip (ver. v1.9.5 )
But, not working. I forget something?
thanks alot in advence for any information.
Regards,
You should check this list.
Also this should be a new topic.
I am very silly. !!
After having changed the internal IP, I assumed that I had the port pointing to the new IP … (but of course) no !!!
Thank you so much, !! surely my node is suspended I do not know because I have almost 24H offline.
(But if so, I deserve it for a fool)
Once again many thanks for the quick response and support !!
You should never have to uninstall storj to get an update. Always check to make sure the update service process is running and it should update on its own.
Yoou have a ponit, thank for that…
Its a good safety measure because if you had reinstalled it and didnt put the right location for the data you would DQ yourself in a matter of hours. If you just started it and didnt check the dashboard right away.
