Node identities are not infinite?
Are there any quantity restrictions considering the number of identities generated with 1 email? I’ve tried to get some tokens but now i am getting the same token again and again.
I am generating identity on the powerful machine and then use it on a less powerfull node.
I think you have to use the identity before you’ll get a different one.
Seems to be so. But i managed to get 2 before meeting this issue
You may create as many identities as you want. However the web site will give you the next authorization token when a previous is used.
The previous two, i guess. I have 2 identites, that are authorized but not used yet.
The key word here -
This action redeems the one-time authorization token.
Sure. But if the previous 2 authorized nodes are not used, the 3rd token will stay the same forever.
Until you use that third one to authorize an identity too.
