OK, so i changed some settings in the config.yaml:
- log.output: ā/app/config/node.logā
- storage2.piece-scan-on-startup: true
- pieces.enable-lazy-filewalker: true
And now i see the following errors in the log.
|2024-09-03T08:23:20Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: G6LN5AHVYPRWOL5ZMMVEPCGEIH6AN4NXGHIYLVFX2R52CY7JYP6Q, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Action: GET, Offset: 0, Size: 768, Remote Address: 172.29.0.1:41888, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:23:20Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: YKO4YVO2M6KDBNNILGJR5P36B6XXJWDKQ4PXY64XDUNL43IRGPRQ, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: GET, Offset: 0, Size: 7168, Remote Address: 172.29.0.1:41860, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:23:20Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: ZEUGM4TTEU6XZKA7JMIPLB2RGUH3WX7C3EUYRGFUIHGOECNBOLWA, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Action: GET, Offset: 0, Size: 768, Remote Address: 172.29.0.1:41884, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:23:20Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: UTMWOPQTGIWMKJMWWVQJMGYVV3J7UHKMWTX5RAURMMSITDSOQ3AQ, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Action: GET, Offset: 0, Size: 256, Remote Address: 172.29.0.1:41850, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:23:38Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: OS3NLUOJH7IQKSG6YDU73I5Q7OTA75OLEYLYSDCWZFKEVWMC3YSQ, Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Action: GET, Offset: 0, Size: 1024, Remote Address: 172.29.0.1:41968, error: trust: rpc: tcp connector failed: rpc: context canceled, errorVerbose: trust: rpc: tcp connector failed: rpc: context canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190}|
|2024-09-03T08:26:02Z|ERROR|piecestore|upload internal error|{Process: storagenode, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:26:02Z|ERROR|piecestore|upload failed|{Process: storagenode, Piece ID: 77GFO77ED37CSU656TKVQHDQOZTU4ETGDVULQ6T2YXPBQMAOQQ2A, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: PUT, Remote Address: 172.29.0.1:44018, Size: 131072, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:28:32Z|ERROR|piecestore|upload internal error|{Process: storagenode, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:28:32Z|ERROR|piecestore|upload failed|{Process: storagenode, Piece ID: ZHLXQYYPMBDIOUKW3DVHGW4DJFBPAT3GAT3R74QRKAFHG75Z6KTA, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: PUT, Remote Address: 172.29.0.1:45672, Size: 65536, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:29:35Z|ERROR|piecestore|upload internal error|{Process: storagenode, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:29:35Z|ERROR|piecestore|upload failed|{Process: storagenode, Piece ID: PXZ6RS6JMXF6JVRX4QTWLXTMFCEEXNXAD4DZXV3XBS3RQHT7MX3A, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: PUT, Remote Address: 172.29.0.1:46348, Size: 196608, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:34:56Z|ERROR|piecestore|upload internal error|{Process: storagenode, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:35:00Z|ERROR|piecestore|upload failed|{Process: storagenode, Piece ID: KG6T6H7343NT5LI2BSTPSRY4EMOSSO77Z6ZUWC6FSTIU2EAMMZNQ, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: PUT, Remote Address: 172.29.0.1:49880, Size: 655360, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:40:50Z|ERROR|piecestore|upload internal error|{Process: storagenode, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:40:50Z|ERROR|piecestore|upload failed|{Process: storagenode, Piece ID: FDVFP56Z5IVATKIU56EEKO24PYQ32TVLL23MOLUZ64RRU7FUEAEQ, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: PUT, Remote Address: 172.29.0.1:54010, Size: 262144, error: manager closed: unexpected EOF, errorVerbose: manager closed: unexpected EOF\n\tgithub.com/jtolio/noiseconn.(*Conn).readMsg:225\n\tgithub.com/jtolio/noiseconn.(*Conn).Read:171\n\tstorj.io/drpc/drpcwire.(*Reader).read:68\n\tstorj.io/drpc/drpcwire.(*Reader).ReadPacketUsing:113\n\tstorj.io/drpc/drpcmanager.(*Manager).manageReader:230}|
|2024-09-03T08:41:47Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Lazy File Walker: true, error: lazyfilewalker: signal: killed, errorVerbose: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:41:47Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Lazy File Walker: false, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:41:47Z|ERROR|piecestore:cache|encountered error while computing space used by satellite|{Process: storagenode, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78, SatelliteID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S}|
|2024-09-03T08:41:47Z|ERROR|piecestore:cache|error getting current used space for trash: |{Process: storagenode, error: filestore error: failed to walk trash namespace 7b2de9d72c2e935f1918c058caaf8ed00f0581639008707317ff1bd000000000: context canceled, errorVerbose: filestore error: failed to walk trash namespace 7b2de9d72c2e935f1918c058caaf8ed00f0581639008707317ff1bd000000000: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).SpaceUsedForTrash:273\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:100\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:41:47Z|ERROR|pieces:trash|emptying trash failed|{Process: storagenode, error: pieces error: lazyfilewalker: signal: killed, errorVerbose: pieces error: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:195\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:436\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89}|
|2024-09-03T08:42:05Z|ERROR|contact:service|ping satellite failed |{Process: storagenode, Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, attempts: 1, error: ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled, errorVerbose: ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190}|
|2024-09-03T08:42:05Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: HW2P4EB54ZD3FY6ND6DMRKV77VQDBO4EKB4K7D2WQOL6XFSV6G6Q, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: GET_REPAIR, Offset: 0, Size: 2319360, Remote Address: 172.29.0.1:55018, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:42:05Z|ERROR|contact:service|ping satellite failed |{Process: storagenode, Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, attempts: 1, error: ping satellite: rpc: tcp connector failed: rpc: context canceled, errorVerbose: ping satellite: rpc: tcp connector failed: rpc: context canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190}|
|2024-09-03T08:42:05Z|ERROR|nodestats:cache|Get pricing-model/join date failed|{Process: storagenode, error: context canceled}|
|2024-09-03T08:42:05Z|ERROR|contact:service|ping satellite failed |{Process: storagenode, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, attempts: 1, error: ping satellite: context canceled, errorVerbose: ping satellite: context canceled\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:202\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:156\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: NE5RAYZ3UDQCBO5FP5YLXGYHA5LBNLOHI3E5BTYNBRMNMXCPQDFA, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: GET_REPAIR, Offset: 0, Size: 17664, Remote Address: 172.29.0.1:55006, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, Lazy File Walker: true, error: lazyfilewalker: signal: killed, errorVerbose: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE, Lazy File Walker: false, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|piecestore:cache|encountered error while computing space used by satellite|{Process: storagenode, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78, SatelliteID: 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE}|
|2024-09-03T08:42:05Z|ERROR|lazyfilewalker.used-space-filewalker|failed to start subprocess|{Process: storagenode, satelliteID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, error: context canceled}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Lazy File Walker: true, error: lazyfilewalker: context canceled, errorVerbose: lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6, Lazy File Walker: false, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|piecestore:cache|encountered error while computing space used by satellite|{Process: storagenode, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78, SatelliteID: 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6}|
|2024-09-03T08:42:05Z|ERROR|lazyfilewalker.used-space-filewalker|failed to start subprocess|{Process: storagenode, satelliteID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, error: context canceled}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Lazy File Walker: true, error: lazyfilewalker: context canceled, errorVerbose: lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, Lazy File Walker: false, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|piecestore:cache|encountered error while computing space used by satellite|{Process: storagenode, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78, SatelliteID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs}|
|2024-09-03T08:42:05Z|ERROR|lazyfilewalker.used-space-filewalker|failed to start subprocess|{Process: storagenode, satelliteID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, error: context canceled}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Lazy File Walker: true, error: lazyfilewalker: context canceled, errorVerbose: lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:133\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:722\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|pieces|used-space-filewalker failed|{Process: storagenode, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Lazy File Walker: false, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|piecestore:cache|encountered error while computing space used by satellite|{Process: storagenode, error: filewalker: context canceled, errorVerbose: filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:731\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:81\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78, SatelliteID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S}|
|2024-09-03T08:42:05Z|ERROR|piecestore:cache|error getting current used space for trash: |{Process: storagenode, error: filestore error: failed to walk trash namespace 7b2de9d72c2e935f1918c058caaf8ed00f0581639008707317ff1bd000000000: context canceled, errorVerbose: filestore error: failed to walk trash namespace 7b2de9d72c2e935f1918c058caaf8ed00f0581639008707317ff1bd000000000: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).SpaceUsedForTrash:273\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:100\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78}|
|2024-09-03T08:42:05Z|ERROR|pieces:trash|emptying trash failed|{Process: storagenode, error: pieces error: lazyfilewalker: signal: killed, errorVerbose: pieces error: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:195\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:436\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:84\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89}|
|2024-09-03T08:42:19Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: YKO4YVO2M6KDBNNILGJR5P36B6XXJWDKQ4PXY64XDUNL43IRGPRQ, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: GET, Offset: 0, Size: 7168, Remote Address: 172.29.0.1:55160, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:42:19Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: YKO4YVO2M6KDBNNILGJR5P36B6XXJWDKQ4PXY64XDUNL43IRGPRQ, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: GET, Offset: 0, Size: 7168, Remote Address: 172.29.0.1:55174, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
|2024-09-03T08:42:19Z|ERROR|piecestore|download failed|{Process: storagenode, Piece ID: SCXOQ5C7U4J444YL4ITIVDIUN43L3N5SUE4BXNVTKBWUEM5URVRQ, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: GET, Offset: 0, Size: 217600, Remote Address: 172.29.0.1:55186, error: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled, errorVerbose: untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:146\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:64\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:666\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35}|
