Hey guys, I am encountering an issue while trying to install Storj Node on my Windows 11 machine. When I execute the storagenode_windows_amd64.msi installer, I am unable to complete the installation process. The following error message is displayed:
There is a problem with this Windows Installer package.
A program run as part of the setup did not finish as expected.
Contact your support personnel or package vendor.
Could you provide guidance on how to resolve this issue?
Thanks for your help.
I will ask the Eningeers, but in the meantime can you tell me if there is anytbing unusual about your Windows configurarion? Is this an S version of Windows or anything like that? Any unusual Group Policies or software packages running on it?
Hi,
My configuration is: Windows 11 Pro, version 23H2. There are no group policies in effect. I also tried installing the MSI package with administrator privileges, but the issue persists.
hi, thanks for the reply these are my logs
reading the logs I understood that it was necessary to delete the storj folder, then I tried to install the program again and now the node works correctly thanks for the help
