Node is OFFLINE Suddenly
Hi!
Up to yesterday, I was running a node in a Synology NAS with no problems. But now it is offline. I’ve tried to stop the container an rerun it, reboot the NAS, reboot the router but no success. Checking the logs, I see the same error:
2020-09-24T16:13:59.375Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 11, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Any knows where it is the problem?
Thanks
You can ignore that error since that satellite has shutdown. Can you show more of your log to get a better picture?
Thanks for the answer. Here it’s the log (I deleted operator email an wallet values):
2020-09-24T15:56:51.435Z INFO Configuration loaded {“Location”: “/app/config/config.yaml”}
2020-09-24T15:56:51.470Z INFO Operator email {“Address”: “"}
2020-09-24T15:56:51.470Z INFO Operator wallet {“Address”: "
2020-09-24T15:56:53.050Z INFO Telemetry enabled
2020-09-24T15:56:53.112Z INFO db.migration Database Version {“version”: 45}
2020-09-24T15:56:54.518Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-09-24T15:56:54.604Z ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “error”: “rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).getSatelliteTime:110\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check.func1:67\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:56:55.345Z INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-09-24T15:56:55.346Z INFO bandwidth Performing bandwidth usage rollups
2020-09-24T15:56:55.346Z INFO Node 12oV5bdzCtFrxTequKDkkTBjH8Pd4Cf62sEfDNBPAJUUDuTT5zo started
2020-09-24T15:56:55.346Z INFO Public server started on [::]:28967
2020-09-24T15:56:55.346Z INFO Private server started on 127.0.0.1:7778
2020-09-24T15:56:55.347Z INFO trust Scheduling next refresh {“after”: “8h37m53.113494219s”}
2020-09-24T15:56:55.553Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 1, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:56:56.638Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 2, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:56:58.710Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 3, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:57:01.335Z ERROR nodestats:cache Get pricing-model/join date failed {“error”: “heldamount service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “heldamount service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/storj/storagenode/heldamount.(*Endpoint).dial:229\n\tstorj.io/storj/storagenode/heldamount.(*Endpoint).GetAllPaystubs:105\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func1:80\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:259\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run:79\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:57:02.794Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 4, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:57:10.876Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 5, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:57:26.970Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 6, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:57:59.050Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 7, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:59:03.131Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 8, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:59:23.940Z ERROR nodestats:cache Get disk space usage query failed {“error”: “node stats service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “node stats service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/storj/storagenode/nodestats.(*Service).dial:159\n\tstorj.io/storj/storagenode/nodestats.(*Service).GetDailyStorageUsage:110\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage.func1:176\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:259\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheSpaceUsage:175\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:131\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T15:59:24.031Z ERROR nodestats:cache heldamount err {“satellite”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”}
2020-09-24T15:59:28.072Z ERROR nodestats:cache Get held amount query failed {“error”: “heldamount service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “heldamount service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/storj/storagenode/heldamount.(*Endpoint).dial:229\n\tstorj.io/storj/storagenode/heldamount.(*Endpoint).GetPaystub:56\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount.func1:202\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:259\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheHeldAmount:194\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func3:136\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T16:00:58.709Z ERROR nodestats:cache Get stats query failed {“error”: “node stats service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “node stats service error: unable to connect to the satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/storj/storagenode/nodestats.(*Service).dial:159\n\tstorj.io/storj/storagenode/nodestats.(*Service).GetReputationStats:66\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheReputationStats.func1:153\n\tstorj.io/storj/storagenode/nodestats.(*Cache).satelliteLoop:259\n\tstorj.io/storj/storagenode/nodestats.(*Cache).CacheReputationStats:152\n\tstorj.io/storj/storagenode/nodestats.(*Cache).Run.func2:119\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T16:01:11.216Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 9, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T16:05:27.297Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 10, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2020-09-24T16:31:03.465Z ERROR contact:service ping satellite failed {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “attempts”: 12, “error”: “ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused”, “errorVerbose”: "ping satellite error: rpccompat: dial tcp 78.94.240.189:7777: connect: connection refused\n\tstorj.io/common/rpc.Dialer.dialTransport:211\n\tstorj.io/common/rpc.Dialer.dial:188\n\tstorj.io/common/rpc.Dialer.DialNodeURL:148\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:124\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.
Hey @nerdatwork! Now it’s online. Do you know why? Apparently, I haven’t changed anything. Thanks.
Satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW has shutdown so the errors related to this can be safely ignored. Unfortunately your log does not show any signs of what could have caused it to go offline. You can try this checklist in the future.
