/processes/storagenode-updater/minimum/url?os=linux&arch=amd64
Resolving version.storj.io (ver)… failed: Temporary failure in name resolution.
wget: unable to resolve host address ‘version.storj.io’
http://: Invalid host name.
downloading storagenode-updater
hi guys , when i was trying to running the storagenode from docker , it fails and gives me this error , does anyone know how to solve it?
Vadim
2
for me it resolving OK, check your DNS configs.
done it multiple times, and i ve tried to run curl or wget , both works
Vadim
4
when you make ping version.storj.io what returns?
Vadim
6
this is Ok ip you get. may be problem that your docker cant get it
Vadim
7
thx, it works , and any idea of this error?
i found the solution on forum, cool
Alexey
10
Hello @nalanshi ,
You missed the setup step, or the mount path in your docker run is wrong.
Please note, the setup step must be performed only once for the newly created node. You should not run it never again for the same identity.
