Node Misconfigured
Hey,
my Node is running several years without any errors or warnings.
In the last time I found the information “Misconfigured” and searched around what goes wrong. Here is what I have checked or think to have it checked right.
My Router forwarded the Ports for TCP & UDP, still active in the Menue of my Router (checked).
Also Open Port Check Tool - Test Port Forwarding on Your Router seems to say ok.
Is seems to have a problem still not with all Satelites ??? I have no idea, what this can tell me.
Also I found a Documentation “QUIC misconfigured” and some other Topics like mine here, where I didn´t found a solution or read over the right Tipp … Than sorry.
Additional here some lines out of a new startet Log:
2025-04-23T15:42:19+02:00	INFO	pieces	used-space-filewalker completed	{"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "Total Pieces Size": 1184823610116, "Total Pieces Content Size": 1182831204612, "Total Pieces Count": 3891417, "Duration": "904.7324ms"}
2025-04-23T15:42:19+02:00	INFO	pieces	used-space-filewalker started	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2025-04-23T15:42:19+02:00	INFO	lazyfilewalker.used-space-filewalker	starting subprocess	{"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2025-04-23T15:42:19+02:00	INFO	lazyfilewalker.used-space-filewalker	subprocess started	{"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2025-04-23T15:42:19+02:00	INFO	lazyfilewalker.used-space-filewalker.subprocess	Database started	{"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Process": "storagenode"}
2025-04-23T15:42:19+02:00	INFO	lazyfilewalker.used-space-filewalker	subprocess finished successfully	{"satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2025-04-23T15:42:19+02:00	INFO	pieces	used-space-filewalker completed	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Lazy File Walker": true, "Total Pieces Size": 259641225984, "Total Pieces Content Size": 259264567552, "Total Pieces Count": 735661, "Duration": "473.6142ms"}
2025-04-23T15:42:19+02:00	INFO	piecestore	downloaded	{"Piece ID": "4IXAF7UW7BTURKF46DENNAN65WIMLL4I5YC2HGUPOETYWYAISVAA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 6912, "Remote Address": "79.127.201.218:45560"}
2025-04-23T15:42:23+02:00	INFO	piecestore	downloaded	{"Piece ID": "5LJXXE6OZ4POGWTLFYDKAEPNOAEZRFQQFIJG4TKKI2OFC3DYRQJQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 7168, "Remote Address": "79.127.201.218:45578"}
2025-04-23T15:42:23+02:00	INFO	piecestore	uploaded	{"Piece ID": "7HE373FUPXMZDPXZUHFU57WDT2RYTMZQ6LE7SJWQACLJISJ3NQMQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.226.103:37306", "Size": 8448}
2025-04-23T15:42:24+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.11.127:39386->10.61.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.11.127:39386->10.61.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:42:24+02:00	INFO	piecestore	downloaded	{"Piece ID": "3YLVME34BZBCUA3OVG2JJYCL4XF6NRQV7UIMWDEFAUERR2ZQX6KQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_AUDIT", "Offset": 2121472, "Size": 256, "Remote Address": "34.21.32.79:37328"}
2025-04-23T15:42:25+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: read udp 10.101.2.10:42542->10.103.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: read udp 10.101.2.10:42542->10.103.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:42:27+02:00	INFO	piecestore	downloaded	{"Piece ID": "DARYOVPJGPKGSWM7SJEM6TRHSCON7OH32IFPNH3LVAUOELX55PLA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 13312, "Remote Address": "109.61.92.86:45294"}
2025-04-23T15:42:29+02:00	INFO	piecestore	downloaded	{"Piece ID": "WOHEXSPAZVCGNPVJ6FNR3IJVMTXCKQL4P3FMBAR27XIQIOVHRFAA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "79.127.205.227:42244"}
2025-04-23T15:42:29+02:00	INFO	piecestore	download canceled	{"Piece ID": "SFS5QLCOOG26UU65NUS4MB34SH22I3AMRYTCTIKKZTK66QWJIL7Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "109.61.92.72:41380", "reason": "downloaded size (0 bytes) does not match received message size (256 bytes)"}
2025-04-23T15:42:31+02:00	INFO	piecestore	downloaded	{"Piece ID": "WOHEXSPAZVCGNPVJ6FNR3IJVMTXCKQL4P3FMBAR27XIQIOVHRFAA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "79.127.205.231:59976"}
2025-04-23T15:42:33+02:00	INFO	piecestore	downloaded	{"Piece ID": "SJEHN6WQB2Z3AQ4XDS7CFJ7J5EARL2NIPFCDQMRAOFR2GDCZBECQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 120832, "Remote Address": "109.61.92.72:56736"}
2025-04-23T15:42:35+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 2, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.10.231:50439->10.61.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.10.231:50439->10.61.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:42:36+02:00	INFO	piecestore	downloaded	{"Piece ID": "6TW2SUVP6QH7GN5CKXG7BNTQYETY4L3LUDA7DBCV2LOY6SR5KOGQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "79.127.205.227:49286"}
2025-04-23T15:42:36+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 2, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: server misbehaving", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: server misbehaving\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:42:38+02:00	INFO	piecestore	downloaded	{"Piece ID": "2TLLUSTQX2CWQZOJDWZRWWTRKD6QKY4SF72NQIJP7WKBAOVPPCIA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 8192, "Remote Address": "79.127.219.34:60428"}
2025-04-23T15:42:38+02:00	INFO	piecestore	uploaded	{"Piece ID": "DCMHOYTCC4WSBCRJIK4CAKRMGVW27I7PD3JVSHJLVCM3GQRNE5JQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "109.61.92.79:34950", "Size": 581632}
2025-04-23T15:42:39+02:00	INFO	piecestore	downloaded	{"Piece ID": "C5IGK62FXFOIELYD4XEUJBEVJIEXK2VH32WKF2SYUJUVVGNZKDIA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 14080, "Remote Address": "109.61.92.72:56742"}
2025-04-23T15:42:40+02:00	INFO	piecestore	downloaded	{"Piece ID": "M5AXEUFB67XTV6MHFPU2KBCG5NHFSLNV7XQVH525WJQMO6NJVA5A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "109.61.92.76:50230"}
2025-04-23T15:42:42+02:00	INFO	piecestore	uploaded	{"Piece ID": "GJYZ2HMYULVNU5GLVI2DELVNXDUNUD5M7M5LDPLPROTK6GKW4PYQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.36:38034", "Size": 2560}
2025-04-23T15:42:42+02:00	INFO	piecestore	uploaded	{"Piece ID": "VT4STKG4SXJMKES7TP63OWQC275HRIFUDO53LAHPWN6LCSIRT7YQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "156.146.43.229:44934", "Size": 1792}
2025-04-23T15:42:42+02:00	INFO	piecestore	download canceled	{"Piece ID": "6B7VF2ZZKRKZMHPMI5OYIBEV3VDPXDIBELYXE54Z43S2HMWX42OQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "79.127.219.35:34622", "reason": "downloaded size (0 bytes) does not match received message size (256 bytes)"}
2025-04-23T15:42:44+02:00	INFO	piecestore	downloaded	{"Piece ID": "JVOSLB3GCXSVA7WGOWF6QSPPPMZAIKYJ2LZWEUZGHHUHO5WPXD7A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 68608, "Size": 256, "Remote Address": "109.61.92.71:60330"}
2025-04-23T15:42:45+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 3, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.11.127:59947->10.61.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.11.127:59947->10.61.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:42:45+02:00	INFO	piecestore	downloaded	{"Piece ID": "T3CZLIR577QPHRT7IGCLV4ANZCZSCDVOAN74HZFZ7L4KINX7QRPA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 15616, "Remote Address": "109.61.92.70:54346"}
2025-04-23T15:42:45+02:00	INFO	piecestore	downloaded	{"Piece ID": "2MOFYTAEDPL23O2ER2IY4Q2OMU45NPGQWXJSLTRXJSHUZ5I5X6AQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "79.127.201.218:54504"}
2025-04-23T15:42:45+02:00	INFO	piecestore	downloaded	{"Piece ID": "7X65XUZD7P6N3HUPFOEPSCNMUWKSZNYUUTRWJJ3IRLLGRZB4IOIA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "109.61.92.74:59030"}
2025-04-23T15:42:46+02:00	INFO	piecestore	uploaded	{"Piece ID": "ZJMWMOBVOYWOZJBS5TJYTTPVYWEJLWY3VND6PJ2DPQI3UM45FXHQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "156.146.43.229:44948", "Size": 2560}
2025-04-23T15:42:49+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 3, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: read udp 10.101.9.13:60134->10.103.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: read udp 10.101.9.13:60134->10.103.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:42:50+02:00	INFO	piecestore	downloaded	{"Piece ID": "XDQSPZY5232N7JYDSXXEQLAX67PVU5PXWKSV2HTMKDIWRD7I4OFQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 8192, "Remote Address": "109.61.92.87:52796"}
2025-04-23T15:42:50+02:00	INFO	piecestore	uploaded	{"Piece ID": "WURIRVISBEHJILJKMJSNSWMQLAL3VOEYY4ASJZV7X5SA2D5B6J6Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.226.106:49780", "Size": 7424}
2025-04-23T15:42:51+02:00	INFO	piecestore	uploaded	{"Piece ID": "45LJU4UIJQA37VEKPLJG7IJZVSSRBAUKI4UEVA2MAVMEYDRDGEPQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "34.21.89.182:4190", "Size": 10}
2025-04-23T15:42:52+02:00	INFO	piecestore	downloaded	{"Piece ID": "45LJU4UIJQA37VEKPLJG7IJZVSSRBAUKI4UEVA2MAVMEYDRDGEPQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 10, "Remote Address": "34.21.89.182:65019"}
2025-04-23T15:42:52+02:00	INFO	piecestore	uploaded	{"Piece ID": "SN6LDZWH34WGEASXTDIE2RMWYVD7CVFUJPJ64SNYVWGJHBZFGXEA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.34:41946", "Size": 2304}
2025-04-23T15:42:54+02:00	INFO	piecestore	downloaded	{"Piece ID": "ALL2VYYREESBB7KF4WFUDDXB25AMEMPIG4362OW42KXPMRMCFS5A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 8192, "Remote Address": "109.61.92.79:41150"}
2025-04-23T15:42:54+02:00	INFO	piecestore	downloaded	{"Piece ID": "GPCNEXP67AIEG4SKQRI3U7ZCNWM3GJUPR6DPBQRN46GODZGXMSHA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "109.61.92.65:38506"}
2025-04-23T15:42:54+02:00	INFO	piecestore	uploaded	{"Piece ID": "X6EBYXVLFUWL2OGU4463IFAVSMV7FBWL4UFURLJDI3UPODLBFORA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.33:58802", "Size": 2048}
2025-04-23T15:42:56+02:00	INFO	piecestore	downloaded	{"Piece ID": "VIRPKIBO26R3PLFZ225BCJGLPI2M52BIGOTCFHGMAGYLJCH6TKAA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 15872, "Remote Address": "109.61.92.70:39660"}
2025-04-23T15:42:56+02:00	INFO	piecestore	uploaded	{"Piece ID": "M6IDYJGPX264AMEWL4OFKRLV2RCO3NAL7XL5YJRW6IBEFQGGAYUQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.43:41132", "Size": 2560}
2025-04-23T15:42:57+02:00	INFO	piecestore	downloaded	{"Piece ID": "XG77P64DIDL3BG3S5Z3SBL55ADJLFDXE3ZDX36JUZHSCTFMTSKQA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 8704, "Remote Address": "109.61.92.79:41182"}
2025-04-23T15:42:57+02:00	INFO	piecestore	uploaded	{"Piece ID": "SQCXU7VFYJTPVHTDUXQF3U2KCNQDZAEMBWPXVBDFJ23JIGMZIVSA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.226.103:37306", "Size": 7168}
2025-04-23T15:42:57+02:00	INFO	piecestore	uploaded	{"Piece ID": "KBVMXT6KOGNBSJJ5BK3HODVEZQOYOT6JW5EZEPQZSL6DAXZWX6BQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.43:41160", "Size": 2304}
2025-04-23T15:42:59+02:00	INFO	piecestore	uploaded	{"Piece ID": "HDRBOMVF2GWRSLPWH2I53J4U3OHW36RLIDLJX3AIHUW756E3DP6A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.33:58808", "Size": 2304}
2025-04-23T15:42:59+02:00	INFO	piecestore	downloaded	{"Piece ID": "KXPNWYHWLFJBYSGPH3DLF24CAVWEIAAIEUEIO777C3S27NDXPFEQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 768, "Remote Address": "156.146.43.226:43882"}
2025-04-23T15:42:59+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 4, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.6.146:47234->10.61.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.6.146:47234->10.61.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:42:59+02:00	INFO	piecestore	uploaded	{"Piece ID": "AUMHL2IYOGVXSS7SBVSBT4CFBIFKV423TI6CLMSH4TDP4NF2L5JQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.44:36558", "Size": 595456}
2025-04-23T15:42:59+02:00	INFO	piecestore	downloaded	{"Piece ID": "M5AXEUFB67XTV6MHFPU2KBCG5NHFSLNV7XQVH525WJQMO6NJVA5A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "109.61.92.87:48698"}
2025-04-23T15:43:01+02:00	INFO	piecestore	downloaded	{"Piece ID": "RTXGIOJBNXN7VCFFEJI5XZA3YJYOJNQCEKM2FJB3TGPVNPFHJ2PA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 9728, "Remote Address": "156.146.43.229:37820"}
2025-04-23T15:43:02+02:00	INFO	piecestore	downloaded	{"Piece ID": "NIZ4U2EWPAZQTHGFZEGMMWZ24EZAYPU74FJXHLQAB5U7JCXHTZDQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 2319104, "Remote Address": "117.20.40.91:53108"}
2025-04-23T15:43:03+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 4, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: read udp 10.101.3.138:37948->10.103.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.103.0.10:53: read udp 10.101.3.138:37948->10.103.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:43:05+02:00	INFO	piecestore	uploaded	{"Piece ID": "DEEVMMIZKLZ2AD5JZZ35ITLYGO5LHRLVPO45A5TASO62TJSI6USA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "109.61.92.71:60330", "Size": 109568}
2025-04-23T15:43:06+02:00	INFO	piecestore	uploaded	{"Piece ID": "RYVUEB6E3WVDWULJOJ6QEPQWGN2YVXVKLQR2DPVGNYH64JNPQD3Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.226.97:41142", "Size": 1792}
2025-04-23T15:43:06+02:00	INFO	piecestore	downloaded	{"Piece ID": "WZXTSSWNKRYXDGDGZJA3NGZB7MBP6XDXBVBR4J4UGUXFGNC7V6NQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 6912, "Remote Address": "109.61.92.71:52036"}
2025-04-23T15:43:09+02:00	INFO	piecestore	downloaded	{"Piece ID": "GABT6E7QSKVLI7VYXVNMAVUPN2QZ3LW4HDZHVANR2ABZCX54DG2A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 11520, "Remote Address": "156.146.43.226:56538"}
2025-04-23T15:43:09+02:00	INFO	piecestore	uploaded	{"Piece ID": "KOUB6Z5B4FWH5BR3UXFKKDARXE67JPBKPUUFHY7TDVXYB3YGDNDA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.226.97:41142", "Size": 275712}
2025-04-23T15:43:10+02:00	INFO	piecestore	uploaded	{"Piece ID": "KV2EJ3B7ZP2LHJWIM5HYTXIGSNVXEOVPZCUNNIBDQAQKRXTEGVOA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.34:56424", "Size": 3840}
2025-04-23T15:43:11+02:00	INFO	piecestore	uploaded	{"Piece ID": "WHDMB7UVSSARI4NJ2GUIHYM3JR5ZZIPCUJD6D2O6VSFCMWBOIRHA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.219.43:59408", "Size": 3840}
2025-04-23T15:43:11+02:00	INFO	piecestore	download canceled	{"Piece ID": "IWAUFKV4SQK4PSZG3OFVHFSRT27FXI3V35I5RDI7WEYNYCY2FLJQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 256, "Remote Address": "109.61.92.79:34950", "reason": "downloaded size (0 bytes) does not match received message size (256 bytes)"}
2025-04-23T15:43:14+02:00	INFO	piecestore	downloaded	{"Piece ID": "TNJETXK7VPO3WFFGTSQCTBQ2Z5YYFN55K6YUDCJG56YYXF3I6GLQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 512, "Remote Address": "79.127.226.104:34230"}
2025-04-23T15:43:15+02:00	INFO	piecestore	uploaded	{"Piece ID": "6MKD72HOSYQ45DK3UWTPAJXDJ4JSJMW2OCR5HLUQJJFL5LZRG3OA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.226.97:41142", "Size": 4608}
2025-04-23T15:43:15+02:00	INFO	piecestore	downloaded	{"Piece ID": "3MKRI2IYIUCXKDFUSNLMJCC2TTW6IWY5DSPDGDPVBYTF52DGGXFQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 8704, "Remote Address": "79.127.205.230:52558"}
2025-04-23T15:43:15+02:00	INFO	piecestore	downloaded	{"Piece ID": "BWSUBQ4SO52BF4JSZSCTSZT5HS33SVOJBFPERM35FVXIT6BH2DFA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 26112, "Remote Address": "79.127.219.36:54222"}
2025-04-23T15:43:16+02:00	INFO	piecestore	download canceled	{"Piece ID": "I4JPN3EYSXPSXMHJGBEFPZKPYXKPTN2XQ4B34IMQ4BTTMSLEJYQA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET", "Offset": 0, "Size": 181248, "Remote Address": "207.211.208.129:44878", "reason": "downloaded size (131072 bytes) does not match received message size (181248 bytes)"}
2025-04-23T15:43:17+02:00	ERROR	contact:service	ping satellite failed 	{"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 5, "error": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.4.56:58869->10.61.0.10:53: i/o timeout", "errorVerbose": "ping satellite: check-in network: failed to resolve IP from address: dragonnode001.duckdns.org:28967, err: lookup dragonnode001.duckdns.org on 10.61.0.10:53: read udp 10.55.4.56:58869->10.61.0.10:53: i/o timeout\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:210\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:158\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:89\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-04-23T15:43:17+02:00	INFO	piecestore	uploaded	{"Piece ID": "QGUR6XBCJV2B36KJVQC74UGZIRDPSTTGZ72GGP4HETGSEYH4MB5A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Remote Address": "79.127.226.98:38320", "Size": 3328}
My Node over all is running, but has a problem that should be corrected.
Any Idea what I have to check next or what I missed? will be welcome.
Thank you
As soon as I saw duckdns in your logs… I knew what was up.
Ignore it.
