My newly stood up Storj node seems to fall offline after some time.
I did carefully follow the steps over at
The port check passes
I manually verified the identity also and see the 6 files with the expected data.
If I start the Docker image, the dashboard says OFFLINE. When I manually ping using this tool, the Dashboard says Online, which seems good. However, no traffic is hitting the node, and I’m skeptical it’s actually working, because after some few hours it goes back into Offline mode. Happened twice in the past ~12 hours. Will keep monitoring…
Storage Node Dashboard ( Node Version: v0.29.3 )
ID 123...
Last Contact ONLINE
Uptime 12h10m34s
Available Used Egress Ingress
Bandwidth 2.0 TB 0 B 0 B 0 B (since Jan 1)
Disk 550.0 GB 0 B
Internal 127.0.0.1:7778
External 34.76.150.93:14002
How long should it normally take for traffic to start flowing into my node? I would have expected a few minutes, not days.
Storj: v0.29.3
Hosting: Kubernetes + GKE with a static IP
