storagenode:alpha needs to be storagenode:beta
In the powershell:
ls E:\identity\storagenode
PS C:\Users\alex> ls E:\identity\storagenode
Directory: E:\identity\storagenode
Mode LastWriteTime Length Name
-a---- 8/2/2019 6:15 PM 546 ca.1564758906.cert
-a---- 8/2/2019 6:15 PM 1076 ca.cert
-a---- 8/2/2019 6:13 PM 241 ca.key
-a---- 8/2/2019 6:15 PM 1088 identity.1564758906.cert
-a---- 8/2/2019 6:15 PM 1618 identity.cert
-a---- 8/2/2019 6:13 PM 241 identity.key
PS C:\Users\alex>
Looks normal.
Please, try to reset the docker from the Docker desktop, then try to run the container again.
how do I reset it ? reinstall or what
Open docker desktop settings, click the âResetâ and select âReset to factory defaultsâ
there is no reset option in my dockerâŚ
Right click on docker icon in your system tray, click Settings, on the left at bottom in the pop up you should see RESET.
I think Im going crazy
Is it docker Enterprise Edition or Community Edition?
comunity⌠âŚ
Your not crazy I see the samething with mine.
I hate docker âŚ
Right click and goto troubleshoot its in there now.
found it, thx, lets see
I reseted to factorry defaults and I still get the same error after accepting to share the drive
C:\Users\alex>docker run -d --restart unless-stopped -p 28967:28967 -e WALLET=â0xDCE74C111f64cD8Cf7aB9480d37E3128B58b8d97â -e EMAIL="alex@upload-drive.com" -e ADDRESS=âupdrv.go.ro:28967â -e BANDWIDTH=â2000TBâ -e STORAGE=â10TBâ --mount type=bind,source=E:\identity\storagenode,destination=/app/identity --mount type=bind,source=E:,destination=/app/config --name storagenode storjlabs/storagenode:alpha
docker: Error response from daemon: invalid mount config for type âbindâ: bind source path does not exist: /host_mnt/e/identity/storagenode.
See âdocker run --helpâ.
any ideeas ?
Can you show your start command your using for docker? It looks like you maybe missing something
this ?
You should be using the updated command
docker run -d --restart unless-stopped -p 28967:28967 -p 127.0.0.1:14002:14002 -e WALLET=â0xXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXâ -e EMAIL="user@example.com" -e ADDRESS=âdomain.ddns.net:28967â -e BANDWIDTH=â20TBâ -e STORAGE=â2TBâ --mount type=bind,source=ââ,destination=/app/identity --mount type=bind,source=ââ,destination=/app/config --name storagenode storjlabs/storagenode:beta
Iâve the same issue, except iâve a problem of connection. I think the update has a serious and general problem for everyone, because the NAT of Docker doesnât exist anymore, and Windows asked me to authorize the app for network, but even after that, and reboot, the same problem occurs. The problem is this update, I regret I upgraded too fast this one, since the others updates didnât did bad thing.
Iâm looking vpnkit-bridge, because its maybe a new process to authorize in the firewall⌠But I disabled all my firewall, and same problem occursâŚ
Can we securaly fall back in the previous version of Docker without losing the nodes ?
