Node not vetted on US1 after 30+ days all other satellites vetted
Hi,
My node has been running since March 9, 2026 and is still not vetted on us1 after more than 30 days. All three other satellites vetted the node around March 30-31.
Node ID: 14nx3k4rfAeadnMdPsExiit6JreCQh6FnbEvesRbAvFNhhupqs
Node version: v1.148.3 (up to date)
Vetting status per satellite:
satelite audit success audit total vetted
ap1 596 596 2026-03-30
eu1 3388 3388 2026-03-31
saltlake 412 416 2026-03-31
us1 403 403 Never
All scores on US1 are perfect:
Audit score: 1.0
Suspension score: 1.0
Online score: 1.0
Audit history score: 1.0
Not suspended, not disqualified
Additional info:
Node joined all satellites on: 2026-03-09
403 successful audits on US1 (well above the 100 vetting threshold)
First audit window on US1: 2026-03-12
QUIC status: OK
Disk allocated: 14.4 TB, used: ~274 GB
No errors in logs related to US1
All other satellites vetted the node within ~21 days. US1 has 403 successful audits with zero failures but vettedAt remains null. Could someone please check if there’s an issue with us1 vetting?
Thanks.
Hello @PaulRichez,
The vetting process a little bit changed, the node should pass at least 100 audits but also not less than a month. I shared your info with the team, maybe something should be adjusted.
To be a little bit more precise: it’s I think 25 days and number of audits is increased and satellite-dependent. I think it’s 1000 for US, bit less for EU and 250 for others. Not sure about exact numbers. Last time for me US as well vetted ~10 days after others. Nothing to worry, just wait
Thank you both for the quick answers!
@Alexey thanks for sharing with the team, I appreciate it.
@hwm.land that makes sense. I wasn’t aware the audit threshold was satellite-dependent (~1000 for US1 vs ~100-250 for others). That explains everything. I currently have ~407 audits on US1, so at ~8 audits/day I should be vetted around end of June. I’ll just wait.
Good to know this is expected behavior and not a bug. I’ll update this thread once vetted
