I moved the node and its identity to different ubuntu pc - PC2 (former had a different node on it but that node was moved back to it original pc - PC1 after recovering that pc from a crash.)
Now the node and idenity on PC3 is moved to pC2 gives these errors for every satellite:
2021-11-06T02:10:57.288Z WARN console:service unable to get Satellite URL {“Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “error”: “console: trust: satellite “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW” is untrusted”, “errorVerbose”: “console: trust: satellite “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW” is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:238\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:177\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:174\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:45\n\tnet/http.HandlerFunc.ServeHTTP:2046\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2878\n\tnet/http.(*conn).serve:1929”}
2021-11-06T02:12:48.353Z ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 10, “error”: “ping satellite: check-in ratelimit: node rate limited by id”, “errorVerbose”: “ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-11-06T02:13:30.202Z
The moved node on PC2 has the same name as the prior node that was on PC2 and which is now on PC1.
Here is the recap
PC1 ubuntnu crashes. Node and identity on PC1 is moved to PC2 - a new ubuntu build, and is running fine. PC1 is fixed (took 3 days). Node and identity on PC2 is then moved back to PC1 and is runnning fine. A different node and identity on PC3 is the moved to a new ubuntu build on PC2. Docker setup looks good:
1c4c58d8c2fe storjlabs/watchtower “/watchtower storage…” 12 minutes ago Up 12 minutes watchtower
7c774aae62fc storjlabs/storagenode:latest “/entrypoint” 19 minutes ago Up 19 minutes 127.0.0.1:14002->14002/tcp, 0.0.0.0:46010->28967/tcp, :::46010->28967/tcp storagenode
But the web dashboard says offline and the log show the errors listed above.
How to fix PC2 without loosing the node?
Any help is greatly appreciate.
EDIT: V1.41.2
