Hi @baker,
Hmm my previous response is under review. Let’s try again, now with the IP removed from the logs.
Run:
sudo docker run -d --restart always --stop-timeout 300 \
-p 28967:28967 \
-p 192.168.1.105:14002:14002 \
-e WALLET="<<removed>>" \
-e EMAIL="<<removed>>" \
-e ADDRESS="<<removed>>:28967" \
-e STORAGE="4.5TB" \
--mount type=bind,source="/mnt/storj/storagenode/identity",destination=/app/identity \
--mount type=bind,source="/mnt/storj/storagenode",destination=/app/config \
Log
2021-09-02T12:03:55.046Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 9, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:07:40.326Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 10, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:07:42.616Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 10, "error": "ping satellite: check-in ratelimit: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:07:50.987Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 10, "error": "ping satellite: check-in ratelimit: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:07:55.849Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 10, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:08:10.696Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 10, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:08:11.819Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 10, "error": "ping satellite: check-in ratelimit: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:138\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:16:12.514Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:16:14.877Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:16:23.489Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:16:28.583Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:16:44.143Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:16:44.960Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 11, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:33:16.654Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 12, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:33:19.154Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 12, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:33:28.083Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 12, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:33:33.283Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 12, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:33:49.614Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 12, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:33:50.076Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 12, "error": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused", "errorVerbose": "ping satellite: failed to dial storage node (ID: 12QSCCTTnRBy2RXdtkE57B9y2RmiuTKaVkSpJVMurcsPycABEss) at address <<removed>>:28967: rpc: dial tcp <<removed>>:28967: connect: connection refused\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-09-02T12:42:33.722Z INFO bandwidth Performing bandwidth usage rollups
