Hello,
after the last automatic update (with watchtower) my node went offline and with “17701600h 43m ago” since the last contract …
Node ID:
12CpDWdqDeKqpyQ2JnLSXb1pXrrAKpojYP9vU5yMnKHYArUMMwW
STATUS
Offline
UPTIME
53h 38m
LAST CONTACT
17701600h 43m ago
VERSION
v1.4.2
PERIOD
May
$ sudo docker logs storagenode --tail 30 -f
2020-05-22T03:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T04:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T05:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T05:35:32.031Z INFO trust Scheduling next refresh {"after": "7h38m6.771197418s"}
2020-05-22T06:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T07:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T08:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T09:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T10:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T11:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T12:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T13:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T13:13:53.371Z INFO trust Scheduling next refresh {"after": "8h18m4.393303469s"}
2020-05-22T14:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T15:04:47.327Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T15:19:50.669Z INFO Got a signal from the OS: "terminated"
Error: debug: http: Server closed
2020-05-22T15:20:38.005Z INFO Configuration loaded {"Location": "/app/config/config.yaml"}
2020-05-22T15:20:38.006Z INFO tracing disabled
2020-05-22T15:20:38.019Z INFO Operator email {"Address": "xxxxxxxxxxxxxxxxxx"}
2020-05-22T15:20:38.019Z INFO Operator wallet {"Address": xxxxxxxxxxxxxxxxx"}
2020-05-22T15:20:38.870Z INFO db.migration Database Version {"version": 38}
2020-05-22T15:20:39.438Z INFO preflight:localtime start checking local system clock with truste d satellites' system clock.
2020-05-22T15:20:40.304Z INFO preflight:localtime local system clock is in sync with trusted sa tellites' system clock.
2020-05-22T15:20:40.305Z INFO trust Scheduling next refresh {"after": "5h15m24.869153971s"}
2020-05-22T15:20:40.305Z INFO Node 12CpDWdqDeKqpyQ2JnLSXb1pXrrAKpojYP9vU5yMnKHYArUMMwW started
2020-05-22T15:20:40.305Z INFO Public server started on [::]:28967
2020-05-22T15:20:40.306Z INFO Private server started on 127.0.0.1:7778
2020-05-22T15:20:40.307Z INFO bandwidth Performing bandwidth usage rollups
2020-05-22T16:20:40.307Z INFO bandwidth Performing bandwidth usage rollups
thanks !
