Hello, after the last update (29.3) my node reports from the web that it is offline, but when I check the logs I do not see any errors, also when I use docker exec -it storagenode /app/dashboard.sh I see that my node is ONLINE .
Maybe some bug?
Maybe some bug?
You can try ctrl + f5
on your dashboard page
Thanks, but I’ve tried, I’ve also used a browser having cleared the cache and I have the same result
Which browser did you use? Use Chrome or Firefox
both of them, Chrome Versión 79.0.3945.117 (Build oficial) (64 bits) and Firefox 72.0.1
I have restarted my server (reboot) and now everything is ok.
