It seems my VPS was rebooted overnight, I had to reconnect an 4TiB storage drive for data but then I got everything started up… but the node is offline. Port is open, date is correct to a second. What have I done wrong?
Dashboard says:
Storage Node Dashboard ( Node Version: v0.22.1 )
ID 1eLJoKbAdMtGHtMSuwrarwGGwBbxzA92NLDP1xT2GA7JYCfBP5
Last Contact OFFLINE
Uptime 10m32s
Available Used Egress Ingress
Bandwidth 99.9 TB 83.4 GB 61.2 GB 22.2 GB (since Oct 1)
Disk 1.8 TB 2.0 TB
Bootstrap
Internal 127.0.0.1:7778
External storj.subwolf.org:28967
Latest lines of log say:
2019-10-09T05:51:37.976Z INFO Node 1eLJoKbAdMtGHtMSuwrarwGGwBbxzA92NLDP1xT2GA7JYCfBP5 started
2019-10-09T05:51:37.976Z INFO Public server started on [::]:28967
2019-10-09T05:51:37.976Z INFO Private server started on 127.0.0.1:7778
2019-10-09T05:51:38.010Z INFO version running on version v0.22.1
2019-10-09T05:51:38.118Z INFO piecestore:monitor Remaining Bandwidth {"bytes": 99916628770048}
2019-10-09T05:51:38.179Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {"count": 45}
2019-10-09T05:51:38.180Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW sending {"count": 549}
2019-10-09T05:51:38.181Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {"count": 101}
2019-10-09T05:51:39.147Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2019-10-09T05:51:39.331Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2019-10-09T05:51:40.245Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW finished
… and thats all. I’ll try restarting again but I’m stumped for now. You said I can use the dev ports and get status? Port 7778 is open.
