Maybe you need mount the HDD in your machine…maybe someone with more expirience with linux can help…
But if you pay 5€ monthly it isnt profitable to you run storj…
Yes, I see what you mean : I am on the 2 GB RAM and the 1 TB will be probably accessible when the volume will be mounted ! I hope so !
Please note : I don’t seek for profit, just for the fun of learning… And ETH will increase, isn’t it ?
Great thanks to you for efficient support of a newbie, @Krystof !!
You can check your available drives:
sudo lsblk
Then prepare the needed disk with fdisk
and mount it via /etc/fstab
The example you can see in this guide:
/dev/sda
hello @Alexey, @Krystof,
About the lack of diskspace, there was an issue with my VPS provider !
After correction, I have now :
I ran again the container without errors. Just one warning in the logs :
021-01-24T19:47:47.266Z WARN trust Failed to fetch URLs from source; used cache {“source”: “https://tardigrade.io/trusted-satellites”, “error”: “HTTP source: Get "https://tardigrade.io/trusted-satellites\”: dial tcp 104.198.14.52:443: i/o timeout", “errorVerbose”: “HTTP source: Get "https://tardigrade.io/trusted-satellites\”: dial tcp 104.198.14.52:443: i/o timeout\n\tstorj.io/storj/storagenode/trust.(*HTTPSource).FetchEntries:63\n\tstorj.io/storj/storagenode/trust.(*List).fetchEntries:90\n\tstorj.io/storj/storagenode/trust.(*List).FetchURLs:49\n\tstorj.io/storj/storagenode/trust.(*Pool).fetchURLs:240\n\tstorj.io/storj/storagenode/trust.(*Pool).Refresh:177\n\tstorj.io/storj/storagenode.(*Peer).Run:821\n\tmain.cmdRun:218\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:842\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:950\n\tgithub.com/spf13/cobra.(*Command).Execute:887\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:385\n\truntime.main:204"}
I think I understand that my node is not part of the “trusted-satellites”…
Otherwise, my port 14002 is still closed (instead of the port 28967 which is open !)
So I can’t have access to the dashboard. That is why I don’t know if my node is finally online.
if you delete “127.0.0.1:” from run command you can access to the dashboard
-p 127.0.0.1:14002:14002
OR - better way
you can try this commnad to view CLI dashboard
docker exec -it storagenode /app/dashboard.sh
Just for info. Anyone who knows your IP (which you posted here) can see your dashboard via the standard port. I would use 127.0.0.1:14002 again and use a reverse proxy OR a VPN. Close your public dashboard.
Remove your personal information from above post. Email, wallet address and static IP.
Hey I looked up that IP and on that /24 subnet there are 3 other nodes. IDK if that is great but if I’m correct it will take longer to fill up as you will be sharing the ingress with 2 other nodes
Hello @Skyblockpro1,
I will test my node a while, just for fun. If necessary, I will give up.
But thanks for your information.
Alain
Your static IP, hostname and wallet are still visible in first post.
Unfortunately, I can’t modify this post any more !
Thanks again…
He is awesome
I removed personal info.
@Krystof would you mind to edit your post with picture on yougetsignal?
@alno
@LinuxNet is right - with exposing your dashboard you expose your personal information, include wallet, email, your earnings, etc.
To access your dashboard it’s better to publish it only locally -p 127.0.0.1:14002:14002
and use a remote access instead: https://documentation.storj.io/resources/faq/how-to-remote-access-the-web-dashboard
Hello @Alexey,
Many thanks for deleting personal informations on my first post.
“-p 127.0.0.1:14002:14002” restored in the run command…
As we say in french : “Pour vivre heureux, vivons cachés” !
Thanks again to all for your support,
Alain
Node OFFLINE - port 28967 closed chek with other ruter contact internet provider no limites Chek firewal setings this hapend after update
