Node OFFLINE - port 28967 closed
You should check everything form this check-list:
I use Dynamic DNS Service by dynu.com ip adress is the same on service and when i chek external ip. I use mikrotik i make rulers port to pc - pc is with static ip i chek same with another ruter and make rulers When go on site for chek open ports 28967 is close .
I call to lokal internet provider i make answer that is no limited ports to my conection.
This make several times and i lost meny time until start to work. But problems become on new updates.
To check the port the service should be up and running.
Could you please provide the last 20 lines from your logs: How do I check my logs? | Storj Docs
2022-08-29T23:23:14.867+0200 INFO Anonymized tracing enabled
2022-08-29T23:23:15.219+0200 INFO Operator email {“Address”: “ail.com”}
2022-08-29T23:23:15.219+0200 INFO Operator wallet {“Address”: “0x2758997dcbc11d2698”}
2022-08-29T23:23:19.425+0200 FATAL Unrecoverable error {“error”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value”, “errorVerbose”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value\n\tstorj.io/storj/storagenode/trust.LoadCacheData:96\n\tstorj.io/storj/storagenode/trust.LoadCache:36\n\tstorj.io/storj/storagenode/trust.NewPool:89\n\tstorj.io/storj/storagenode.New:379\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:378\n\tstorj.io/private/process.cleanup.func1:396\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tstorj.io/private/process.ExecWithCustomConfig:75\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2022-08-30T10:23:55.574+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2022-08-30T10:23:55.578+0200 INFO Anonymized tracing enabled
2022-08-30T10:23:55.614+0200 INFO Operator email {“Address”: “ail.com”}
2022-08-30T10:23:55.614+0200 INFO Operator wallet {“Address”: “0x2758997dcbc11d2”}
2022-08-30T10:23:59.876+0200 FATAL Unrecoverable error {“error”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value”, “errorVerbose”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value\n\tstorj.io/storj/storagenode/trust.LoadCacheData:96\n\tstorj.io/storj/storagenode/trust.LoadCache:36\n\tstorj.io/storj/storagenode/trust.NewPool:89\n\tstorj.io/storj/storagenode.New:379\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:378\n\tstorj.io/private/process.cleanup.func1:396\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tstorj.io/private/process.ExecWithCustomConfig:75\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2022-08-30T13:20:50.348+0200 INFO Anonymized tracing enabled {“Process”: “storagenode”}
2022-08-30T13:20:50.486+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2022-08-30T13:20:50.486+0200 INFO Anonymized tracing enabled
2022-08-30T13:20:50.491+0200 INFO Operator email {“Address”: “mail.com”}
2022-08-30T13:20:50.491+0200 INFO Operator wallet {“Address”: “0x2758997dcbc11d5”}
2022-08-30T13:20:51.019+0200 FATAL Unrecoverable error {“error”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value”, “errorVerbose”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value\n\tstorj.io/storj/storagenode/trust.LoadCacheData:96\n\tstorj.io/storj/storagenode/trust.LoadCache:36\n\tstorj.io/storj/storagenode/trust.NewPool:89\n\tstorj.io/storj/storagenode.New:379\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:378\n\tstorj.io/private/process.cleanup.func1:396\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tstorj.io/private/process.ExecWithCustomConfig:75\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2022-08-30T16:43:24.165+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2022-08-30T16:43:24.179+0200 INFO Anonymized tracing enabled
2022-08-30T16:43:24.233+0200 INFO Operator email {“Address”: “tmail.com”}
2022-08-30T16:43:24.235+0200 INFO Operator wallet {“Address”: “0x2758997dcbc11d269826d79d549ffc9775”}
2022-08-30T16:43:25.486+0200 FATAL Unrecoverable error {“error”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value”, “errorVerbose”: “trust: malformed cache: invalid character ‘\x00’ looking for beginning of value\n\tstorj.io/storj/storagenode/trust.LoadCacheData:96\n\tstorj.io/storj/storagenode/trust.LoadCache:36\n\tstorj.io/storj/storagenode/trust.NewPool:89\n\tstorj.io/storj/storagenode.New:379\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:378\n\tstorj.io/private/process.cleanup.func1:396\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tstorj.io/private/process.ExecWithCustomConfig:75\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
I solved the problem by reinstalling the computer. However, he caused problems. Now back in shape everyone is at 70% and going up
