Someone has made some serious xit with my node. I’m reconfiguring it! the error that appear is this one. storagewars@raspberrypi:~/Hds/HD1 $ sudo service docker start Job for docker.service failed because a fatal signal was delivered causing the control process to dump core. See "systemctl status docker.service" and "journalctl -xe" for details. storagewars@raspberrypi:~/Hds/HD1 $ ░ The job identifier is 2066. Feb 10 20:02:36 raspberrypi systemd[1]: docker.service: Main process exited, code=dumped, status=11/SEGV ░░ Subject: Unit process exited ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ An ExecStart= process belonging to unit docker.service has exited.
Only ssh works on the PI
Had it working over VNC. After a crash doesn’t boot properly. Purchased a microhdmi still doesn’t show image even on VNC. Rebuild writable windows partition on sd card to include ssh file. Removed 1 drive. Edited fstab file. Turns on and i can connect over ssh… After all this docker doesn’t work! ![]()
Some guides on to make it work are appreciated
I had experience with RPi when you install image on SD rather use RPi imager tool. I think it’s depreciated but maybe it’s still somewhere around. Where you can also set SSH config.
But when you did fresh install why still so much trouble? Maybe hardware related?
You said remove 1 drive how many drives are on RPi? you know its USB is not very powerful I wouldn’t power any disk with RPi usb only
Thank you for your reply! The drive connected is powered. How to make it work? I can connect over ssh but i can’t make docker to start it’s service!
A segunda, 10/02/2025, 23:24, LxdrJ via Storj Community Forum (official) <noreply@forum.storj.io> escreveu:
How did you install docker? On what OS?
Cmd line it’s running a 32bit version
A terça, 11/02/2025, 06:35, LxdrJ via Storj Community Forum (official) <noreply@forum.storj.io> escreveu:
Something like this?
https://docs.docker.com/engine/install/raspberry-pi-os/#install-using-the-repository
It’s your advice? Will try it later today!
A terça, 11/02/2025, 08:23, LxdrJ via Storj Community Forum (official) <noreply@forum.storj.io> escreveu:
I had it working previously. After it crashed it doesn’t work. I will try to install it later on. Maybe tomorrow. I don’t have time today.
A terça, 11/02/2025, 08:40, Tiago Carvalho <tcarvalho85@gmail.com> escreveu:
I´ve got some typos here:
2025-02-11T18:22:57Z ERROR piecestore:cache error getting current used space for trash: {"Process": "storagenode", "error": "filestore error: failed to walk trash namespace af2c42003efc826ab4361f73f9d890942146fe0ebe806786f8e7190800000000: context canceled", "errorVerbose": "filestore error: failed to walk trash namespace af2c42003efc826ab4361f73f9d890942146fe0ebe806786f8e7190800000000: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).SpaceUsedForTrash:302\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:105\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11T18:22:57Z INFO lazyfilewalker.trash-cleanup-filewalker subprocess exited with status {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "status": -1, "error": "signal: killed"}
2025-02-11T18:22:57Z ERROR pieces:trash emptying trash failed {"Process": "storagenode", "error": "pieces error: lazyfilewalker: signal: killed", "errorVerbose": "pieces error: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:196\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:486\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:86\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2025-02-11T18:22:57Z ERROR failure during run {"Process": "storagenode", "error": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory\n\tstorj.io/storj/storagenode/monitor.(*Service).verifyStorageDir:161\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:109\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Error: piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory
2025-02-11 18:22:57,512 INFO stopped: storagenode (exit status 1)
2025-02-11 18:22:57,514 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM) ```
after editing the start of the node i get:
```2025-02-11T18:39:33Z INFO Anonymized tracing enabled {"Process": "storagenode"}
2025-02-11T18:39:33Z INFO Operator email {"Process": "storagenode", "Address": "tcar#5@gmail.com"}
2025-02-11T18:39:33Z INFO Operator wallet {"Process": "storagenode", "Address": "0x20ba0ed29b38f63cfe96193b1e858a"}
2025-02-11T18:39:33Z ERROR failure during run {"Process": "storagenode", "error": "Error opening database on storagenode: group:\n--- stat config/storage/blobs: no such file or directory\n--- stat config/storage/temp: no such file or directory\n--- stat config/storage/trash: no such file or directory", "errorVerbose": "Error opening database on storagenode: group:\n--- stat config/storage/blobs: no such file or directory\n--- stat config/storage/temp: no such file or directory\n--- stat config/storage/trash: no such file or directory\n\tmain.cmdRun:69\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:272"}
Error: Error opening database on storagenode: group:
2025-02-11 18:39:33,706 INFO exited: storagenode (exit status 1; not expected)
2025-02-11 18:39:34,708 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
2025-02-11 18:39:35,710 WARN received SIGQUIT indicating exit request
2025-02-11 18:39:35,711 INFO waiting for processes-exit-eventlistener, storagenode-updater to die
2025-02-11T18:39:35Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2025-02-11 18:39:35,715 INFO stopped: storagenode-updater (exit status 0)
storagewars@raspberrypi:~/Hds/HD1/storage $ ls
bandwidth.db garbage heldamount.db notifications.db piece_expiration.db pieceinfo.db pricing.db satellites.db storage_usage.db trash used_space_per_prefix.db
blobs garbage_collection_filewalker_progress.db info.db orders.db piece_expirations piece_spaced_used.db reputation.db secret.db temp used_serial.db
Guidance here would be welcome!
What does „ls -lh“ show in storage folder?
Why do you post email and wallet address in public forum?
my mistake! here’s the output
storagewars@raspberrypi:~/Hds/HD1 $ ls -lh
total 60K
-rwxrwxrwx 1 storagewars storagewars 11K Jun 7 2024 config.yaml
drwxrwxrwx 2 storagewars storagewars 4.0K Nov 30 2023 ID2
drwxrwxrwx 2 storagewars storagewars 4.0K Nov 30 2023 lost+found
drwxrwxrwx 4 storagewars storagewars 4.0K Aug 29 2023 orders
drwxr-xr-x 2 root root 4.0K May 20 2024 retain
-rwxrwxrwx 1 storagewars storagewars 32K Feb 11 20:09 revocations.db
drwxrwxrwx 7 storagewars storagewars 4.0K Feb 11 20:09 storage
-rw------- 1 root root 1.9K Feb 11 20:09 trust-cache.json
storagewars@raspberrypi:~/Hds/HD1/storage $ ls -lh
total 476K
-rwxrwxrwx 1 storagewars storagewars 36K Feb 11 20:10 bandwidth.db
drwxrwxrwx 6 root root 4.0K Aug 29 2023 blobs
drwxrwxrwx 2 storagewars storagewars 4.0K Apr 7 2024 garbage
-rw-r--r-- 1 root root 24K Feb 11 20:10 garbage_collection_filewa lker_progress.db
-rwxrwxrwx 1 storagewars storagewars 32K Feb 11 20:10 heldamount.db
-rwxrwxrwx 1 storagewars storagewars 16K Feb 11 20:10 info.db
-rwxrwxrwx 1 storagewars storagewars 24K Feb 11 20:10 notifications.db
-rwxrwxrwx 1 storagewars storagewars 32K Feb 11 20:10 orders.db
-rwxrwxrwx 1 storagewars storagewars 36K Feb 11 20:10 piece_expiration.db
drwxrwxrwx 2 storagewars storagewars 4.0K Feb 11 18:21 piece_expirations
-rwxrwxrwx 1 storagewars storagewars 24K Feb 11 20:10 pieceinfo.db
-rwxrwxrwx 1 storagewars storagewars 24K Feb 11 20:10 piece_spaced_used.db
-rw-r--r-- 1 root root 24K Feb 11 20:10 pricing.db
-rwxrwxrwx 1 storagewars storagewars 24K Feb 11 20:10 reputation.db
-rw-r--r-- 1 root root 32K Feb 11 20:10 satellites.db
-rwxrwxrwx 1 storagewars storagewars 24K Feb 11 20:10 secret.db
-rw-r--r-- 1 root root 24K Feb 11 20:10 storage_usage.db
drwxrwxrwx 2 storagewars storagewars 36K May 6 2024 temp
drwxrwxrwx 6 root root 4.0K Apr 19 2024 trash
-rwxrwxrwx 1 storagewars storagewars 20K Feb 11 20:10 used_serial.db
-rwxrwxrwx 1 storagewars storagewars 24K Feb 11 20:10 used_space_per_prefix.db
storagewars@raspberrypi:~/Hds/HD1/storage $v ```
should change ownership and permissions?
Yes Docker run user has no permission on root folder
all to root or storagewars? All to drwxrwxrwx? Changing user owner now
storagewars@raspberrypi:~ $ sudo su
root@raspberrypi:/home/storagewars# cd /
root@raspberrypi:/# chown -R storagewars: /home/storagewars/Hds/HD1/storage
can’t change owner on blobs and on trash
root@raspberrypi:/# ls -l /home/storagewars/Hds/HD1/storage/
total 476
-rwxrwxrwx 1 storagewars storagewars 36864 Feb 11 20:37 bandwidth.db
drwxrwxrwx 6 root root 4096 Aug 29 2023 blobs
drwxrwxrwx 2 storagewars storagewars 4096 Apr 7 2024 garbage
-rw-r--r-- 1 storagewars storagewars 24576 Feb 11 20:37 garbage_collection_filewalker_progress.db
-rwxrwxrwx 1 storagewars storagewars 32768 Feb 11 20:37 heldamount.db
-rwxrwxrwx 1 storagewars storagewars 16384 Feb 11 20:37 info.db
-rwxrwxrwx 1 storagewars storagewars 24576 Feb 11 20:37 notifications.db
-rwxrwxrwx 1 storagewars storagewars 32768 Feb 11 20:37 orders.db
-rwxrwxrwx 1 storagewars storagewars 36864 Feb 11 20:37 piece_expiration.db
drwxrwxrwx 2 storagewars storagewars 4096 Feb 11 18:21 piece_expirations
-rwxrwxrwx 1 storagewars storagewars 24576 Feb 11 20:37 pieceinfo.db
-rwxrwxrwx 1 storagewars storagewars 24576 Feb 11 20:37 piece_spaced_used.db
-rw-r--r-- 1 storagewars storagewars 24576 Feb 11 20:37 pricing.db
-rwxrwxrwx 1 storagewars storagewars 24576 Feb 11 20:37 reputation.db
-rw-r--r-- 1 storagewars storagewars 32768 Feb 11 20:37 satellites.db
-rwxrwxrwx 1 storagewars storagewars 24576 Feb 11 20:37 secret.db
-rw-r--r-- 1 storagewars storagewars 24576 Feb 11 20:37 storage_usage.db
drwxrwxrwx 2 storagewars storagewars 36864 May 6 2024 temp
drwxrwxrwx 6 root root 4096 Apr 19 2024 trash
-rwxrwxrwx 1 storagewars storagewars 20480 Feb 11 20:37 used_serial.db
-rwxrwxrwx 1 storagewars storagewars 24576 Feb 11 20:37 used_space_per_prefix.db
root@raspberrypi:/#
update
2025-02-11T20:55:58Z INFO failed to sufficiently increase send buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details. {"Process": "storagenode"}
2025-02-11T20:55:58Z ERROR services unexpected shutdown of a runner {"Process": "storagenode", "name": "piecestore:monitor", "error": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory\n\tstorj.io/storj/storagenode/monitor.(*Service).verifyStorageDir:161\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:109\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11T20:55:58Z ERROR nodestats:cache Get pricing-model/join date failed {"Process": "storagenode", "error": "context canceled"}
2025-02-11T20:55:58Z ERROR version failed to get process version info {"Process": "storagenode", "error": "version checker client: Get \"https://version.storj.io\": context canceled", "errorVerbose": "version checker client: Get \"https://version.storj.io\": context canceled\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tstorj.io/storj/private/version/checker.(*Client).Process:89\n\tstorj.io/storj/private/version/checker.(*Service).checkVersion:104\n\tstorj.io/storj/private/version/checker.(*Service).CheckVersion:78\n\tstorj.io/storj/storagenode/version.(*Chore).checkVersion:115\n\tstorj.io/storj/storagenode/version.(*Chore).RunOnce:71\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/storj/storagenode/version.(*Chore).Run:64\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11T20:55:58Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup ap1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2025-02-11T20:55:58Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2025-02-11T20:55:58Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2025-02-11T20:55:58Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2025-02-11T20:55:58Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup us1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2025-02-11T20:55:58Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2025-02-11T20:55:58Z ERROR contact:service ping satellite failed {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled", "errorVerbose": "ping satellite: rpc: tcp connector failed: rpc: dial tcp: lookup eu1.storj.io: operation was canceled\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190"}
2025-02-11T20:55:58Z INFO contact:service context cancelled {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2025-02-11T20:55:58Z INFO piecemigrate:chore all enqueued for migration; will sleep before next pooling {"Process": "storagenode", "active": {}, "interval": "10m0s"}
2025-02-11T20:55:58Z ERROR piecestore:cache error during init space usage db: {"Process": "storagenode", "error": "piece space used: context canceled", "errorVerbose": "piece space used: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).Init:55\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:65\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11T20:55:58Z INFO lazyfilewalker.trash-cleanup-filewalker subprocess exited with status {"Process": "storagenode", "satelliteID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "status": -1, "error": "signal: killed"}
2025-02-11T20:55:58Z ERROR pieces:trash emptying trash failed {"Process": "storagenode", "error": "pieces error: lazyfilewalker: signal: killed", "errorVerbose": "pieces error: lazyfilewalker: signal: killed\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:85\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkCleanupTrash:196\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:486\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:86\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89"}
2025-02-11T20:55:58Z ERROR failure during run {"Process": "storagenode", "error": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory\n\tstorj.io/storj/storagenode/monitor.(*Service).verifyStorageDir:161\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:109\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11 20:55:58,576 INFO exited: storagenode (exit status 1; not expected)
2025-02-11 20:55:59,583 INFO spawned: 'storagenode' with pid 47
2025-02-11 20:55:59,585 WARN received SIGQUIT indicating exit request
2025-02-11 20:55:59,586 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2025-02-11T20:55:59Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2025-02-11 20:55:59,593 INFO stopped: storagenode-updater (exit status 0)
2025-02-11 20:55:59,596 INFO stopped: storagenode (terminated by SIGTERM)
2025-02-11 20:55:59,597 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
update3
2025-02-11T21:05:01Z INFO pieces used-space-filewalker started {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2025-02-11T21:05:01Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2025-02-11T21:05:01Z ERROR lazyfilewalker.used-space-filewalker failed to start subprocess {"Process": "storagenode", "satelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "error": "context canceled"}
2025-02-11T21:05:01Z ERROR pieces used-space-filewalker failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": true, "error": "lazyfilewalker: context canceled", "errorVerbose": "lazyfilewalker: context canceled\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*process).run:73\n\tstorj.io/storj/storagenode/pieces/lazyfilewalker.(*Supervisor).WalkAndComputeSpaceUsedBySatellite:134\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:774\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11T21:05:01Z ERROR pieces used-space-filewalker failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": false, "error": "filewalker: used_space_per_prefix_db: context canceled", "errorVerbose": "filewalker: used_space_per_prefix_db: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSpacePerPrefixDB).Get:81\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:96\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:83\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:783\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11T21:05:01Z ERROR piecestore:cache encountered error while computing space used by satellite {"Process": "storagenode", "error": "filewalker: used_space_per_prefix_db: context canceled", "errorVerbose": "filewalker: used_space_per_prefix_db: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSpacePerPrefixDB).Get:81\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatelliteWithWalkFunc:96\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:83\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkAndComputeSpaceUsedBySatellite:783\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78", "SatelliteID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2025-02-11T21:05:01Z ERROR piecestore:cache error getting current used space for trash: {"Process": "storagenode", "error": "filestore error: failed to walk trash namespace af2c42003efc826ab4361f73f9d890942146fe0ebe806786f8e7190800000000: context canceled", "errorVerbose": "filestore error: failed to walk trash namespace af2c42003efc826ab4361f73f9d890942146fe0ebe806786f8e7190800000000: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).SpaceUsedForTrash:302\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:105\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2025-02-11T21:05:01Z ERROR failure during run {"Process": "storagenode", "error": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory", "errorVerbose": "piecestore monitor: error verifying location and/or readability of storage directory: open config/storage/storage-dir-verification: no such file or directory\n\tstorj.io/storj/storagenode/monitor.(*Service).verifyStorageDir:161\n\tstorj.io/common/sync2.(*Cycle).Run:102\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:109\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
Why not User: group?
like this? chown -R storagewars:storagewars /home/storagewars/Hds/HD1/storage
can’t change user ![]()
root@raspberrypi:/# cd home/storagewars/Hds/HD1/storage/trash
root@raspberrypi:/home/storagewars/Hds/HD1/storage/trash# ls -lh
total 16K
drwxrwxrwx 5 storagewars storagewars 4.0K May 20 2024 pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa
drwxrwxrwx 4 root root 4.0K May 18 2024 qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa
drwxrwxrwx 5 root root 4.0K May 20 2024 ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa
drwxrwxrwx 4 storagewars storagewars 4.0K May 19 2024 v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa
root@raspberrypi:/home/storagewars/Hds/HD1/storage/trash# cd ..
root@raspberrypi:/home/storagewars/Hds/HD1/storage# cd blobs
root@raspberrypi:/home/storagewars/Hds/HD1/storage/blobs# ls -lh
total 80K
drwx------ 1026 root root 20K Feb 18 2024 pmw6tvzmf2jv6giyybmmvl4o2ahqlaldsaeha4yx74n5aaaaaaaa
drwx------ 1026 root root 20K Sep 5 2023 qstuylguhrn2ozjv4h2c6xpxykd622gtgurhql2k7k75wqaaaaaa
drwx------ 1026 root root 20K Aug 30 2023 ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa
drwxrwxrwx 1026 root root 20K Aug 31 2023 v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa
Do you think that removing root assigned files could make the node comeback online?
A terça, 11/02/2025, 20:27, LxdrJ via Storj Community Forum (official) <noreply@forum.storj.io> escreveu:
