sudo docker logs --tail 20 storj2
2020-11-02T13:16:48.368Z INFO Operator wallet {"Address": "[ADDRESS]"}
2020-11-02T13:16:48.624Z INFO Telemetry enabled
2020-11-02T13:16:48.649Z INFO db.migration Database Version {"version": 45}
2020-11-02T13:16:49.488Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2020-11-02T13:16:50.084Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2020-11-02T13:16:50.084Z INFO bandwidth Performing bandwidth usage rollups
2020-11-02T13:16:50.085Z INFO Node [NODE_ID] started
2020-11-02T13:16:50.085Z INFO Public server started on [::]:28967
2020-11-02T13:16:50.085Z INFO Private server started on 127.0.0.1:7778
2020-11-02T13:16:50.086Z INFO trust Scheduling next refresh {"after": "7h3m9.61227678s"}
2020-11-02T13:17:10.306Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {"count": 141}
2020-11-02T13:17:10.306Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {"count": 151}
2020-11-02T13:17:10.307Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {"count": 88}
2020-11-02T13:17:10.306Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {"count": 115}
2020-11-02T13:17:10.306Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {"count": 123}
2020-11-02T13:17:10.495Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S finished
2020-11-02T13:17:10.691Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE finished
2020-11-02T13:17:10.905Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2020-11-02T13:17:11.253Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2020-11-02T13:17:11.490Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB finished
ad407fb2b9b9 storjlabs/storagenode:latest "/entrypoint" 12 minutes ago Up 12 minutes 0.0.0.0:14002->14002/tcp, 0.0.0.0:28967->28967/tcp storj2
a560db1a10ee storjlabs/watchtower "/watchtower watchto…" 46 minutes ago Up 46 minutes watchtower
After updating my node manually and re-running I’m getting stats indicating that my node is down but I’m not sure why, any thoughts?
Updated to latest version and relaunched according to the guide on storj software updates.
UPDATE:
Following the guide here: Node stopped responding overnight. Still shows OFFLINE after restart - #6 by Alexey helped! My router grabbed a new ip and the computer that I have no-ip installed on was not with me. I’ll need to investigate no-ip for my linux server. The timing of the two events was curiously close.
UPDATE 2: (since I’ve personally benefited from mining these forums)
I’m going to assuming having no-ip on a laptop was a bad idea and the new ip allocation was really no-ip grabbing the ip location of the laptop that my wife took to work (personal laptop that she uses to do homework in down time) Anywho, this caused the node to go offline. I went ahead and added this script as a 10min cron job to the server (computer) running storj GitHub - theonemule/no-ip: A shell script that works as Dynamic Update Client (DUC) for noip.com
I’ve now got automated docker image updates and automated ip lookups on the host device.
