Hi all,
My node is offline, im using windows 10 with gui, i check the logs and it shows me this error:
021-08-04T19:26:37.029+0200 INFO db.migration Database Version {“version”: 53}
2021-08-04T19:26:37.206+0200 FATAL Unrecoverable error {“error”: “Error during preflight check for storagenode databases: preflight: database “bandwidth”: failed create test_table: database disk image is malformed\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).preflight:418\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).Preflight:352\n\tmain.cmdRun:208\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:64\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”, “errorVerbose”: “Error during preflight check for storagenode databases: preflight: database “bandwidth”: failed create test_table: database disk image is malformed\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).preflight:418\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).Preflight:352\n\tmain.cmdRun:208\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:64\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57\n\tmain.cmdRun:210\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.Exec:65\n\tmain.(*service).Execute.func1:64\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
What should i do? thank you all.
