Node often shuts down and need to be manually started
Hello - i have a node that often closes down and needs to be restarted.
the logs i got from it is:
2024-02-06T23:21:14+01:00 ERROR gracefulexit:chore error retrieving satellites. {“error”: “satellitesdb: database is locked”, “errorVerbose”: “satellitesdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits:192\n\tstorj.io/storj/storagenode/gracefulexit.(*Service).ListPendingExits:59\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).AddMissing:55\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run:48\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2024-02-06T23:21:14+01:00 ERROR services unexpected shutdown of a runner {“name”: “forgetsatellite:chore”, “error”: “database is locked”}
2024-02-06T23:21:14+01:00 ERROR piecestore:cache error getting current used space: {“error”: “filewalker: context canceled; filewalker: context canceled; filewalker: context canceled”, “errorVerbose”: “group:\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n— filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:69\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:74\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:726\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:51\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2024-02-06T23:21:14+01:00 ERROR orders cleaning DB archive {“error”: “ordersdb: database is locked”, “errorVerbose”: “ordersdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*ordersDB).CleanArchive:325\n\tstorj.io/storj/storagenode/orders.(*Service).CleanArchive:157\n\tstorj.io/storj/storagenode/orders.(*Service).Run.func2:141\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/common/sync2.(*Cycle).Start.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2024-02-06T23:21:15+01:00 ERROR pieces:trash emptying trash failed {“error”: “pieces error: filestore error: context canceled”, “errorVerbose”: “pieces error: filestore error: context canceled\n\tstorj.io/storj/storagenode/blobstore/filestore.(*blobStore).EmptyTrash:176\n\tstorj.io/storj/storagenode/pieces.(*BlobsUsageCache).EmptyTrash:316\n\tstorj.io/storj/storagenode/pieces.(*Store).EmptyTrash:416\n\tstorj.io/storj/storagenode/pieces.(*TrashChore).Run.func1.1:83\n\tstorj.io/common/sync2.(*Workplace).Start.func1:89”}
2024-02-06T23:21:28+01:00 FATAL Unrecoverable error {“error”: “database is locked”}
Check your disk for errors.
I see a database locked error, so your disk can’t keep up. You could move db-es on ssd or usb stick. I just moved mines on Samsung Bar Plus 128GB, and works fine for 2 nodes. But it is verry soon to tell about reliability.
I will give this a try with a spare SSD - thanks alot.
