Node on test net not starting due to missing file on github
Title says it all
--2023-02-27 17:40:32--  https://github.com/storj/storj/releases/download/v1.73.3-rc/storagenode_linux_amd64.zip
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2023-02-27 17:40:32 ERROR 404: Not Found.
I’ve let the team know. Should follow up soon.
@BrightSilence how are you running this node? Is it on Docker or as part of a storj-up or storj-sim setup, or something else?
I don’t think anything should be trying to use v1.73.3-rc at this point.
As instructed here: Please join our public test network
https://version.qa.storj.io/ points to this version.
Oh! I didn’t even know about that. Ok it looks like we may have missed a step in the v1.73.3-rc release. I’ll follow up.
Follow up: we’re going to replace it with v1.73.4. Should be fixed on version.qa.storj.io soon.
Seems to be fixed now, thanks!
Issue seems to be back, but with the updater this time. I see v1.73.4 is being rolled out though, so I may just have to be patient until it’s my nodes turn.
--2023-03-10 08:52:35--  https://github.com/storj/storj/releases/download/v1.73.3-rc/storagenode-updater_linux_amd64.zip
Resolving github.com (github.com)... 140.82.121.4
Connecting to github.com (github.com)|140.82.121.4|:443... connected.
2023-03-10 08:52:36 ERROR 404: Not Found.
I’ve switched to the non qa version server for now… at least I can keep my test node online that way
