Read the title lol
If dashboard shows offline then port forwarding is not properly done. Can you elaborate how did you forward it ?
Never mind… I used ngrok instead and now it works. I might want to troubleshoot this in the future though. I am running this on an Azure VM, and port forwarded through the Azure portal.
Clear Temp Files in Browser.
Tried that… I just used ngrok
