Node Questions about Crashing, Upload Failed, and Other Node Issues
So I was wondering why my node occasionally crashes. Wasn’t able to see any reason in the logs for it.
Why does it never mention upload successful? I only see cancelled or upload failed.
What would be the reason that my drive is showing I am storing like 750 MB but the web UI is showing 50.
Is it normal that all of my satellites are showing 100% (Suspension, Audit, and Online)
Is it normal that I only have ingress but no exgress?
Here are my latest logs
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “N3WSZBN6FHIBU244ZYKZL7QGA7PJ5RNVB7AYOMKL45FNLTJD7J4A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 8704, “Remote Address”: “38.104.84.243:44954”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “FE7XGOUM5MY3S54EX4R3MUIE7B2D57OC5GKJE63LR3ES25XYGO5Q”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 21760, “Remote Address”: “5.161.128.79:25958”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “ARVL32PPLCCAVGCWSS3UDZ4MJXU24UQCZWFQAGHMASPXONTA75OQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 7680, “Remote Address”: “5.161.128.79:22212”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “UWWPTYZ6KBEOSPDHAML47C7F7YXVCWBBTXSYHWSK2FE5CHBLVCQQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 22016, “Remote Address”: “5.161.128.79:24500”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “KQJP7TYBT2YIAFPGQVZETLCGDRHQTLWWXIU56EXBEOPSAEC6FDBQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 1792, “Remote Address”: “5.161.143.41:41544”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “ICTQ5C55ZNGYY4U5GAYJSTISPDXE6UYROVUHBAESYTMDADR3E4EQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 17408, “Remote Address”: “5.161.149.40:63114”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “XAZBQVQZVRAUPNSNNDHOXSXWWBWK4G66GLSR566N7EDMILHOUJXA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 18688, “Remote Address”: “5.161.143.41:36476”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “YMI44LJPKERTDDMCKJOPEVDGHSNO54TLMY7IWX5KBF5SA4FAI2WA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 36352, “Remote Address”: “5.161.128.79:21170”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “2WDK34ZI7ZPCGOQF3LMWFDVRDLC6OT73PIN5HWXVXQZC3ODGHGQA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 36352, “Remote Address”: “5.161.128.79:39656”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “IMEYCMSHRF34ZT7ZOXBI5XUGSLDG6VOVTRUR7M2UA277TQQ7JXNQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 15872, “Remote Address”: “72.52.83.202:8520”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “DMYRTVVXF3QWWR7ZHAXLNAR4T6H3E7UYNSPYIMHILNFVQ2ZRESNA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 3072, “Remote Address”: “72.52.83.202:33520”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “7XBBDIJPEKWADSLWT6CCAVPMTZPFP4TPFHDJZLQRTVGP7SVJNLNA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 36864, “Remote Address”: “5.161.149.40:57526”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “RCQPQIXEHGVML37V5K5GMY4O7RIY2OFSZWCTRBYA6GVNSFLPRSYA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 18688, “Remote Address”: “5.161.143.41:41574”}
2023-08-05T09:58:21-07:00 ERROR piecestore upload failed {“Piece ID”: “Z5IHFIQUV5H3YD36AQBZCKBS2BX4HZRXKWV2XEKHLGUE2PM6FDXQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 14080, “Remote Address”: “72.52.83.202:36516”}
2023-08-05T09:58:22-07:00 ERROR piecestore upload failed {“Piece ID”: “P4YQUXRX7TMU4XZY344JVDALPCZSW6UFT4WSDSFC4IHWERVSHCQQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 32768, “Remote Address”: “5.161.128.79:36588”}
2023-08-05T09:58:22-07:00 ERROR piecestore upload failed {“Piece ID”: “QU64DCOHCHFLQ4DH37CTBMVCBBULMFE4WT3E2QQEHLHBDQIF4K2A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 14336, “Remote Address”: “38.104.84.242:42852”}
2023-08-05T09:58:22-07:00 ERROR piecestore upload failed {“Piece ID”: “AK2AXM3DPKPBJVU4DEZY3GQCCCJ5FZ3ZCHRBGNSS3EJBOK2ZBHWA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 28928, “Remote Address”: “5.161.128.79:43900”}
2023-08-05T09:58:23-07:00 ERROR piecestore upload failed {“Piece ID”: “N7ECBP76VFCDRL6UUC5W33IPR446KHT32FPFFCZC6FPB6FNGHPTQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 1536, “Remote Address”: “5.161.143.41:51742”}
2023-08-05T09:58:24-07:00 ERROR piecestore upload failed {“Piece ID”: “RQ5NT7EC2BNZMJGDZOJXJBRSNTP2X47AXCBAL64SJTDTEILZ2CWQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35”, “Size”: 36864, “Remote Address”: “5.161.149.40:45962”}
2023-08-05T09:58:24-07:00 FATAL Unrecoverable error {“error”: “piecestore monitor: timed out after 1m0s while verifying readability of storage directory”, “errorVerbose”: “piecestore monitor: timed out after 1m0s while verifying readability of storage directory\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1.1:148\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func1:140\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
Try to check docker logs (if you run Docker). Also filter storagenode log and find “FATAL”.
open config.yaml, change your log.level to “info”, save it and restart the node
post your screenshot
normal, and it’s good
How old is your node? and by “no” you mean zero? Zero is abnormal, >0 is normal.
See
