Node receiving no ingress
Node dashboard is showing no ingress over the last 4 days, online score had dropped to 71.1% after my previous error involving DNS the other day. But this shouldn’t affect the node getting new traffic would it? I’m still seeing “GET’s” in the logs.
2022-06-20T09:48:22.032554524Z 2022-06-20T09:48:22.032Z WARN console:service unable to get Satellite URL {“Process”: “storagenode”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “error”: “console: trust: satellite "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW" is untrusted”, “errorVerbose”: “console: trust: satellite "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW" is untrusted\n\tstorj.io/storj/storagenode/trust.(*Pool).getInfo:238\n\tstorj.io/storj/storagenode/trust.(*Pool).GetNodeURL:177\n\tstorj.io/storj/storagenode/console.(*Service).GetDashboardData:186\n\tstorj.io/storj/storagenode/console/consoleapi.(*StorageNode).StorageNode:45\n\tnet/http.HandlerFunc.ServeHTTP:2047\n\tgithub.com/gorilla/mux.(*Router).ServeHTTP:210\n\tnet/http.serverHandler.ServeHTTP:2879\n\tnet/http.(*conn).serve:1930”}
You can ignore the warn message. Satellite 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW was retired a long time ago.
As for the ingress, what version are you running?
The 71% you see on the dashboard could be outdate. Maybe you have been suspended (or disqualified)? If you restart your node it should request updated numbers from each satellite within a few minutes.
I’m still sending egress & repair data
Still above suspension/disqualification thresholds AFAIK though they’ve not budged the last few days… (not better, but not worse) I think it’s averaged over the last 60-day period so might take a few more days to bring down the 7-day outage
Was that the stefan-benten test satellite?
Could your node be full?
Would you call this full?
500MB free & 690GB in trash?
Yes I would call that full and that explains why you don’t get any uploads.
I think that huge trash is because of your long offline.
The satellites may have had to repair some blocks and you have been left out.
Once the trash expires in a few days your node will start to fill again.
The new data seems to include lots of deletes so that 600G could last some months.
Time to start a second node?
Yes
Post must be at least 20 characters
