The first one indicates that your node have problems with QUIC, did you configure it: Step 4. Configure QUIC - Storj Docs?
The second one is a funny coincidence - a PieceID has the word “FATAL”.
Since you do not have a node restarts because of FATAL errors, then this error
may indicate that you could have a firewall.
Please provide result of the command:
sudo ufw status
Also, you do not need to have
in the config.yaml, if you use docker, it will be overridden by the command line arguments.
If you have port mapping in your docker run command as
-p 127.0.0.1:14002:14002 \
then you need to remove 127.0.0.1: from the docker run to make it:
You need to check your router and firewall, why it’s prevent connection from this satellite.
You may also check when your node was not available for that satellite:
