Node running but browser dashboard not working
Good morning,
I was hoping that someone might be able to help me out with my node. I’m a bit of a novice, but got the node running on a rock 4 SE with an external 5TB HDD.
I set up and started the node with the docker command outlined in the get started guide, and using the cli dashboard it shows that the node is online and running properly.
Storage Node Dashboard ( Node Version: v1.95.1 )
ID 17hj3eDtfCxFdFdzjzpknihnANcjAhi4sjVzPm8RrkL8eBwkvw
Status ONLINE
Uptime 95h24m14s
               Available          Used      Egress      Ingress
 Bandwidth           N/A     102.06 GB     3.13 GB     98.94 GB (since Jan 1)
      Disk       4.30 TB      98.95 GB
Internal 127.0.0.1:7778
External xxxxxxxxx.ddns.net:28967
However, when I go to the web UI, shows offline, 0B of storage and no satellite connections (attached image). Does anyone have any idea why this might be happening?
Any help would be much appreciated!
Hi @dubcomesaveme ,
Can you please post the last 20 lines from your logs?
https://docs.storj.io/node/faq/check-logs
This will help the team diagnose the issue.
Thank you!
Hi @bre,
Please see below:
2024-01-31T14:23:40Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “2M4HRWMERNID3DNVHABUFY2AJFLCT6HOQXEVOXV32XRAY56FBETQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4297955776384, “Remote Address”: “79.127.220.99:44294”}
2024-01-31T14:23:40Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “2M4HRWMERNID3DNVHABUFY2AJFLCT6HOQXEVOXV32XRAY56FBETQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 1024, “Remote Address”: “79.127.220.99:44294”}
2024-01-31T14:23:41Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “FVTXFLUDD6HBE562RDOM5TSTC77XVLPEZ44ZPEBNJEPIYEKEQCCA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Available Space”: 4297955774848, “Remote Address”: “79.127.226.98:39826”}
2024-01-31T14:23:41Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “FVTXFLUDD6HBE562RDOM5TSTC77XVLPEZ44ZPEBNJEPIYEKEQCCA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Size”: 17152, “Remote Address”: “79.127.226.98:39826”}
2024-01-31T14:23:41Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “4N5WYL5SCX5ZMDM6KQATXYPPG4BHSPZ2AD3ACO5WJM44R7NVLWJA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 181504, “Remote Address”: “79.127.220.98:42716”}
2024-01-31T14:23:41Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “L7RSFFW2XN4CN6PEBOLIDGCIK2OLRF5VT3DDUJNM7GIDZXB6ZKRQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Available Space”: 4297955575168, “Remote Address”: “79.127.226.98:55226”}
2024-01-31T14:23:42Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “PIK5JYR4GTILF6DTOOJNPLFHZMFU7TMVU5YT7NM6TUEMWG56ADMQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4297955575168, “Remote Address”: “79.127.220.97:41564”}
2024-01-31T14:23:42Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “PIK5JYR4GTILF6DTOOJNPLFHZMFU7TMVU5YT7NM6TUEMWG56ADMQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 11008, “Remote Address”: “79.127.220.97:41564”}
2024-01-31T14:23:42Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “F6EWJVEMJP7N4DS7PUVAG45QRUNFISIZMBJJ4MNSF5PQ74COJGOA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4297955563648, “Remote Address”: “5.161.128.79:38072”}
2024-01-31T14:23:42Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “F6EWJVEMJP7N4DS7PUVAG45QRUNFISIZMBJJ4MNSF5PQ74COJGOA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 4096, “Remote Address”: “5.161.128.79:38072”}
2024-01-31T14:23:42Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “WXRDK77AVS27R6Y6Y2TH4BQGIU3OOGT4FFBC4624254OOT3LZEKQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4297955559040, “Remote Address”: “79.127.219.33:46934”}
2024-01-31T14:23:42Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “WXRDK77AVS27R6Y6Y2TH4BQGIU3OOGT4FFBC4624254OOT3LZEKQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 30720, “Remote Address”: “79.127.219.33:46934”}
2024-01-31T14:23:43Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “TTIGVA22FIYRXW7IWXRRHWE4RFZBRGIYS2RQ2HU2Z5N3EYXQJLMA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4297955527808, “Remote Address”: “79.127.205.225:37922”}
2024-01-31T14:23:43Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “TTIGVA22FIYRXW7IWXRRHWE4RFZBRGIYS2RQ2HU2Z5N3EYXQJLMA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 310272, “Remote Address”: “79.127.205.225:37922”}
2024-01-31T14:23:44Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “XSW3QRIA3SZOQ6LQZOWO4O7RGCESL3P4FDLUVDADCAPDSFD4DBGQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4297955217024, “Remote Address”: “79.127.219.34:40782”}
2024-01-31T14:23:44Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “XSW3QRIA3SZOQ6LQZOWO4O7RGCESL3P4FDLUVDADCAPDSFD4DBGQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 1536, “Remote Address”: “79.127.219.34:40782”}
2024-01-31T14:23:44Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “BB4RLZXHOTYW345TNZEKV7X5DOXARVCMXP2AN4PLPE57QKN6BIEQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Size”: 2319360, “Remote Address”: “79.127.226.97:36290”}
2024-01-31T14:23:44Z INFO piecestore download started {“process”: “storagenode”, “Piece ID”: “54Q3UXADAYEDOA2NXKRTKXJ2G3DRPQUWOKFTGTW4SN7TAWUPTG7Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”, “Offset”: 0, “Size”: 13312, “Remote Address”: “79.127.213.33:54292”}
2024-01-31T14:23:44Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “NJS6TA3NE7IVUBLGLEMMLTCQ4VXEV7QBKFG7YJIAQ2AZYG2IESFA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4297952895104, “Remote Address”: “79.127.220.98:42716”}
2024-01-31T14:23:44Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “NJS6TA3NE7IVUBLGLEMMLTCQ4VXEV7QBKFG7YJIAQ2AZYG2IESFA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 1536, “Remote Address”: “79.127.220.98:42716”}
Thank you @dubcomesaveme
I’ve forwarded your question to the team and someone will return with a reply.
thanks bre, much appreciated <3
Could you provide what browser you are using and output from browser console?
Your screenshot is from 5 minutes after starting. I would wait a bit and then fully refresh the page (Not just use the refresh button in the tool itself) and it should show you different results. When a node first starts up, the dashboard doesn’t necessarily have all the correct information as the node is still running some processes which can delay it for a little bit.
Hi,
Thanks for your replies.
I am using Brave browser, the output from the console is as shown in attached picture.
I have tried refreshing it now and it says " 192.168.1.183 refused to connect."
Is the node itself still running? You can check the logs for ‘fatal’ to see if it may have crashed.
As far as I am aware it is still running, the disk space used is increasing.
Are you on Windows? Strange that it was working and then stopped. Firewall? I would check the logs to see if there are errors.
Please try to use a different browser.
Hi all,
Thanks for all the help so far.
So checking the logs, every 15 mins or so I get t he following:
2024-02-01T08:00:27Z INFO piecestore upload canceled (race lost or node shutdown) {“process”: “storagenode”, “Piece ID”: “QROSJIZMXQC2TY5CSBEOIB47Q4ZG6QYZKOS3K77OREPTPT544AWA”}
It then proceeds to upload again and confirm success.
2024-02-01T08:00:27Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “2XB6PMPB23KXJD37CMUS77UGPZDGIJTT62T5XSK4BG6WBRLONEHA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4289178701440, “Remote Address”: “5.161.128.79:34882”}
2024-02-01T08:00:27Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “2XB6PMPB23KXJD37CMUS77UGPZDGIJTT62T5XSK4BG6WBRLONEHA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 36352, “Remote Address”: “5.161.128.79:34882”}
Opening the dashboard on a different browser yields the same results.
A few more questions:
  • what operating system you are using?
  • did you try different browser?
  • are you able to provide console.address your node has configured?
  • can you check if you are able to access http://<node_ip>:14002/api/sno/satellites?
The upload canceled is normal. Your node was slower than other nodes during this particular transfer. When that happens, your connection is dropped when another node has fulfilled the transfer request. This is normal behavior as all nodes lose some races.
Hi Michaln,
  • Ubuntu 20.04.6 LTS
  • Yes, different browsers get the same result
  • console.address: 0.0.0.0:14002
  • This site can’t be reached
Then you need to check your logs for a FATAL errors, they are interrupt the Storagenode to run.
Hi Alexey,
Thanks for your reply. Very newbie question here, but how do I do that please? I did a google and was looking for var/log/syslog but don’t seem to have that file
For docker:
docker logs storagenode 2>&1 | grep FATAL | tail
Thanks Alexey,
I was looking through the logs, and i have occasional lines such as below:
2024-01-29T05:35:48Z WARN contact:service Your node is still considered to be online but encountered an error. {“process”: “storagenode”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Error”: “contact: failed to ping storage node using QUIC, your node indicated error code: 0, rpc: quic: timeout: no recent network activity”}
from the command that you linked, I get the following 2 liens:
2024-02-01T07:23:29Z INFO piecestore upload started {“process”: “storagenode”, “Piece ID”: “FFOVY5SEYNDKJFATALTDKZOWDD3J5MUAMVPK7MESFULHIFFCGHEA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Available Space”: 4289464400768, “Remote Address”: “79.127.219.34:46770”}
2024-02-01T07:23:30Z INFO piecestore uploaded {“process”: “storagenode”, “Piece ID”: “FFOVY5SEYNDKJFATALTDKZOWDD3J5MUAMVPK7MESFULHIFFCGHEA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 372480, “Remote Address”: “79.127.219.34:46770”}
