Node september statistic suddenly changed
That is correct unfortunately.
Is it prevent to submit orders?
The corruption itself can’t be fixed by the code so far. So our devs are fixed only consequences.
After the fix the node should be able to submit other orders and do not stuck on this error.
I would recommend to select each satellite and summarize the payout, since this version can’t show the summary payout because of Stefan satellite
Yes, orders are not submitted unless corrupted file is removed manually.
This is weird, because of
Are you sure that your node stuck with that error on v1.13.3?
100%. I have the log to prove it.
