2019-09-12T20:08:55.561+0200 FATAL Unrecoverable error {“error”: "error occurred while signing certificate: rpc error: code = Unknown desc = authorization error: authorization has already been claimed:
Long story short, node setup ended in literally clusterfuck… now my email address is burned and i have to wait another 4 days for a new node invite…
How does this happen?
Usually, signing the identity and then losing the files for some reason. Unfortunately it happens more often than you would think even though the instructions tell you to back them up right after.
when you try to upgrade your hypervisor and it all goes to shits while installing a node…
