Approx. two days ago the node stopped working out of a sudden!? I am not aware of the reason nor did I do changes, updates or any of the sort. I am stuck with the log message not knowing what to do:
2024-01-22T16:09:38Z FATAL Unrecoverable error {“process”: “storagenode”, “error”: “trust: open config/trust-cache.json: permission denied”, “errorVerbose”: “trust: open config/trust-cache.json: permission denied\n\tstorj.io/storj/storagenode/trust.LoadCacheData:105\n\tstorj.io/storj/storagenode/trust.LoadCache:36\n\tstorj.io/storj/storagenode/trust.NewPool:91\n\tstorj.io/storj/storagenode.New:405\n\tmain.cmdRun:79\n\tmain.newRunCmd.func1:32\n\tstorj.io/private/process.cleanup.func1.4:393\n\tstorj.io/private/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomOptions:112\n\tmain.main:30\n\truntime.main:267”}
Version is as of today latest.
There are no other log errors.
Renaming the json didn´t work, it wasn´t recreated.
Any help is appreciated.
Additional infos needed? Don´t hesitate to request.
Existing topics seem to be very old, couldn´t get to know what to do.
@Alexey I opt in for bullet point number 1 and I am currently changing the owner back to root again.
You were right with the newly added --user, I had a offline problem with the node recently (~start of january or alike) and updated the socker command with the wiki also because of QUIC.
The node is switching between suspended states now. I hope the best.
Can you asses how long the owner change will take for a 18TB node?
(Ah it would be such a pitty to loose that node… it is finally full after ~4 years (?)… grrr…)
In short - I have no idea, how long it would take on your system.
You wouldn’t lose your node if you did not lose more than 4% of data. With online score below 60% your node will be suspended, but you can recover it being 30 days online.
