hi. after update come 0.21.1 node crash every night… whats can be a problem?
Hi @Madbrain!
I recommend using uptimerobot (free), for monitor your node (setup two probe: ping your external IP, and check storagenode port). I think problem not on your side…
Try having a look at the logs to see what’s happening at the time it stopped.
i have some errors on log
ERROR server gRPC unary error response {“error”: “rpc error: code = PermissionDenied desc = untrusted peer 1QzDKGHDeyuRxbvZhcwHU3syxTYtU1jHy5duAKuPxja3XC8ttk”}
ERROR server gRPC stream error response {“error”: “piecestore protocol: rpc error: code = Canceled desc = context canceled”, “errorVerbose”: “piecestore protocol: rpc error: code = Canceled desc = context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:267\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:151\n\tstorj.io/storj/pkg/pb._Piecestore_Upload_Handler:1070\n\tstorj.io/storj/pkg/server.(*Server).logOnErrorStreamInterceptor:23\n\tgoogle.golang.org/grpc.(*Server).processStreamingRPC:1127\n\tgoogle.golang.org/grpc.(*Server).handleStream:1178\n\tgoogle.golang.org/grpc.(*Server).serveStreams.func1.1:696”}
ERROR server gRPC stream error response {“error”: “piecestore: piecestore protocol: rpc error: code = Canceled desc = context canceled”, “errorVerbose”: “piecestore: piecestore protocol: rpc error: code = Canceled desc = context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func3:546\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Those are all pretty normal, not an indication of an actual issue. It could be running out of memory. You may want to monitor that.
strange… node taked 35% memory… on server have 2gb ram.
