one of my nodes is stuck on v1.95.1. Per the dashboard it is still receiving ingress but I’m concerned that will end if it does not update soon. I tried rebooting the PC, removing and reinstalling the docker node, stopping removing and reinstalling the docker watchtower. But still on v1.95.1. My other docker node is fine and running v1.99.3. This was all done over a two day period.
How log should I wait for the version to update?
Is the anything else I can do?
Rollout is still underway. See version.storj.io the cursor there is all F’s when the rollout is done. Right now it starts with a 7. It’s not your nodes turn yet. Just be patient.
Thanks for the fast response.
i mean, You are not a slave of version.
You can install whatever You want, even a test one 1.101.3:
I don’t know how can you install what you want on Docker…
There’s a risk to using unreleased versions before release as some versions will upgrade your databases, making them incompatible with older versions. So if you run into issues with that newer version, you might not be able to downgrade anymore and end up being stuck. I highly recommend sticking to the normal update rollout schedule.
