Storj has always gracefully handled iSCSI slice expansions, but this time around after I raised it to 3TB to increase earnings…
Instead, my node gets suspended after the Storj process seems to have crashed earlier this morning. (5-9)
Restarting Storj and it now recognizes the additional TB of space, as it did not at time of expansion after I went to bed.
How long does it take to get out of suspend?
All audit checks and uptimes show 100% on all of the satellites.
Interesting log bits:
|2020-05-09T01:06:12.971-0400|ERROR|telemetry|Failed sending report|
{“error”: “lookup collectora.storj.io: no such host”}
|2020-05-09T01:06:51.152-0400|ERROR|telemetry|Failed sending report|{“error”: “lookup collectora.storj.io: no such host”}|
|2020-05-09T01:07:22.969-0400|INFO|piecestore|download started|{“Piece ID”: “A66DBL3IDY4NVFFOQ63REO6NVF2RV4SMITJ4JWIDGHUWBVVSDFFA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_REPAIR”}|
|2020-05-09T01:07:22.970-0400|ERROR|piecestore|download failed|{“Piece ID”: “A66DBL3IDY4NVFFOQ63REO6NVF2RV4SMITJ4JWIDGHUWBVVSDFFA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_REPAIR”, “error”: “usedserialsdb error: disk I/O error: The device is not ready.”, “errorVerbose”: “usedserialsdb error: disk I/O error: The device is not ready.\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSerialsDB).Add:35\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:76\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:523\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:471\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:66\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}|
2020-05-09T06:47:52.873-0400 | ERROR | piecestore:cache | error persisting cache totals to the database: | {“error”: “piece space used error: disk I/O error: The device is not ready.”, “errorVerbose”: “piece space used error: disk I/O error: The device is not ready.\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).UpdatePieceTotals:174\n\tstorj.io/storj/storagenode/pieces.(*CacheService).PersistCacheTotals:100\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:85\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:80\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func1:56\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”} |
2020-05-09T06:47:56.135-0400 | INFO | piecestore | download started | {“Piece ID”: “GNTPN7XZJE6KCQCOOJI2KPGETYXLINCH7I3YYQ5NUSC7CIRT6D4Q”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET”} |
2020-05-09T06:47:56.136-0400 | ERROR | piecestore | download failed | {“Piece ID”: “GNTPN7XZJE6KCQCOOJI2KPGETYXLINCH7I3YYQ5NUSC7CIRT6D4Q”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET”, “error”: “usedserialsdb error: disk I/O error: The device is not ready.”, “errorVerbose”: “usedserialsdb error: disk I/O error: The device is not ready.\n\tstorj.io/storj/storagenode/storagenodedb.(*usedSerialsDB).Add:35\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:76\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload:523\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Download:471\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:995\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:66\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:111\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:62\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:99\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”} |
