Node suspended for being offline
i have a node that was having some hardware issues and was offline for a while. its back to 87% uptime and was not disqualified.
two questions
contrary to docs it does seem to be getting data ingress, which it sounds like its not supposed to. any idea why?
when will get get reinstated? seemed like it should have been unsuspended after hitting 80% uptime.
Hello @miles_gloriosus,
If your online score is greater than 60%, then your node is likely un-suspended.
Do you have any other issues like using an old version of storagenode: Where can I check for a new version? - Storj Docs, or having a suspension score below 60%?
It could be also possible that your node could “think” that’s full.
its running the same version as my other long running node.
suspension and audit scores in the UI are bot 100%.
it has ~3tb free.
Then you need just wait. If the node is online and the version is v1.155.4, it should accept a new traffic unless it is sure that it’s full. If you have a multinode dashboard, it should show the free space as it’s reported to satellites.
