hey guys i just got this message:
“Your node has been suspended on 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE .” Sat, 06 Jun 2020 13:44:12 GMT
what do I need to do? it looks like its ok on other satellites
I’m running it on version 1.5.2 on docker on a Synology nas
uptime checks show 98.9%
and audit check 100%
my node id is:
12p89dN6cAUQy6scEWodqRUe2AE15vSCRMCQ5M5CdjLeJRfe8Wf
Please, check your logs for GET_AUDIT and failed
Please, try to restart your node.
Is Storj working on any fixes in regards to database locks or is it up to the storj operators to vacuum and maintain their own nodes regularly?
hmmm it looks like it fixed the issue… the question is why has this happened?
Used serials will be moved to memory with the next release. This issue was picked up with priority after it became clear it was causing suspensions and disqualification after suspension was disabled. At this point I would just wait for that release.
