Node Suspension - serial already exists in store
Hello,
I’ve been a node operator since February of 2019, and today I’ve noticed my main node (~16.4TB stored) has been suspended from europe-north-1.tardigrade.io:7777 (12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB)
Looking around, I see this GitHub issue: GET REPAIR errors showing up on storage nodes · Issue #4687 · storj/storj · GitHub
The errors I’m receiving are similar to those presented there:
2022-04-19T17:37:22.102Z        INFO    piecestore      download started        {"Piece ID": "HFS3LO35OZYVZRQUCNAWIMLQVEUGQOD4Q45CRBDRIG6ZM3FIHGVA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR"}
2022-04-19T17:37:22.102Z        ERROR   piecestore      download failed {"Piece ID": "HFS3LO35OZYVZRQUCNAWIMLQVEUGQOD4Q45CRBDRIG6ZM3FIHGVA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "used serial already exists in store", "errorVerbose": "used serial already exists in store\n\tstorj.io/storj/storagenode/piecestore/usedserials.insertSerial:263\n\tstorj.io/storj/storagenode/piecestore/usedserials.(*Table).Add:117\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:76\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:498\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2022-04-19T17:37:27.431Z        INFO    piecestore      download started        {"Piece ID": "WWVN5WZNDJTM5KWW67ZSVK2ROSILG37CKY6UVE7XFK2YPH75LR4Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR"}
2022-04-19T17:37:29.324Z        INFO    piecestore      downloaded      {"Piece ID": "WWVN5WZNDJTM5KWW67ZSVK2ROSILG37CKY6UVE7XFK2YPH75LR4Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR"}
With the GitHub link I posted above, can someone from Storj confirm that I’m experiencing the same issue? I’m seeing similar errors within the ap1.storj.io (121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6) node as well.
Is there any actions I need to do on my end? My Uptime is going on 300h+, and QUIC is “OK”. I have 5 total nodes, and all appear to be exhibiting this issue (and they’re at different locations).
Yes it’s the same. Long discussion here and implications also here.
Update for the satellites causing this issue already on the go.
Crossing fingers. :v:t2:
If the issue still occurs today or later, please let storjlings know here.
Hello all,
My node has been running for a little over a year now, but lately I’ve noticed that the suspension score from the satellites across the Atlantic have been sliding down. I really can’t figure out what is causing this. The US based satellites haven’t been affected.
This seems to be the typical error message:
2022-05-26T17:42:20.107Z ERROR piecestore download failed {“Process”: “storagenode”, “Piece ID”: “EQYRH2RNA6XROSM2OFUB2W4CJWLDRP5SAFDIFGTKAES22GZPWY4Q”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_REPAIR”, “error”: “used serial already exists in store”, “errorVerbose”: “used serial already exists in store\n\tstorj.io/storj/storagenode/piecestore/usedserials.insertSerial:263\n\tstorj.io/storj/storagenode/piecestore/usedserials.(*Table).Add:117\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:76\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:498\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52”}
I’d like some help in diagnosing the problem.
Thanks in advance!
