Node Suspension
From my storj-sim tests I would say yes but if you give me your nodeID I can double check that.
@Alexey & @littleskunk isn’t the nodeID as the walledID supposed to stay private?
Thanks
they are public. Both :slight_smile:
the only private information that they belongs to you.
The private key is must be private.
So if you concerned regarding NodeID, you can file a ticket on support.storj.io but it will be longer
how can i get the docker logs for 2020-04-22 at 23:51 UTC. this time? ive been trying to do it for an hour now but --tail doesn’t work
Not concerned, just was not sure it was the right approach. Thank you @Alexey for explaining it.
@littleskunk, can you then please check the state of nodeID 1HMY6GyJKwkaZNveHLpp3a7VrdSVzuF1bufqMsLhRALQfDpUVo
Thanks
@Alexey my node is 12UzxJS8iFiYuL7AqpSE7tmjkp8B4aCNopjNZ5yrQP3TBymgCzc
Is it the node.log file I need to look at? It is almost 6 GB, is it safe to archive what is current so it is easier to open in the future?
I have no idea how to browse the docker logs… tried outputing it to file, didnt work, tried --tail 100 didnt work… tried --since YYYY-MM-DD didnt work…
What is the correct syntax for it because the ones i find on google do not work…
Not suspended right now.
OK its enough… im been here for 3 hours and dont care if i get DQ d because of it…
This is my node ID: 12WgXYY2c4W7H4sTCwbhykfNYnm1tRdB2kR3RaCvh6qFY1dKCLN
If you have any idea whats happening to it give me an update.
Ohh and this is my success rate ( still didnt finish )
Critically failed: 0
Critical Fail Rate: 0.000%
Recoverable failed: 0
Recoverable Fail Rate: 0.000%
Successful: 5835
Success Rate: 100.000%
Failed: 2161
Fail Rate: 0.836%
Canceled: 22475
Cancel Rate: 8.690%
Successful: 233982
Success Rate: 90.474%
Rejected: 0
Acceptance Rate: 100.000%
Failed: 157
Fail Rate: 0.009%
Canceled: 1125756
Cancel Rate: 65.173%
Successful: 601428
Success Rate: 34.818%
Failed: 0
Fail Rate: 0.000%
Canceled: 0
Cancel Rate: 0.000%
Successful: 1239
docker logs --since 2020-04-22T23:50:00Z storagenode
To find failed audits:
docker logs --since 2020-04-22T23:50:00Z storagenode 2>&1 | grep failed | grep GET_AUDIT
Or just audits:
docker logs --since 2020-04-22T23:50:00Z storagenode 2>&1 | grep GET_AUDIT
Good evening… been running a successful node for nearly a year and was surprised by two satellite suspensions today from asia-east-1 and us-central-1.
I did notice an excessive CPU issue that has been corrected and may have contributed to this. I’ve had this situation before and it never led to suspension notices. Examination of the past few days’ node logs do not demonstrate any failed audits.
I’ve restarted as of 55m ago as of this post time. Can I get a read on Node ID 1X2crR3NdPwht5vUvWGdi2qy9Wd13h7KpLfipsBrfg3mETns4i
Hello @refined,
it could be started but never finished audit download.
Please, try to search some errors on timestamp of the email
Finally got my log:
pi@storjpi:~ $ docker logs --since 2020-04-22T18:00:00Z storagenode 2>&1 | grep GET_AUDIT
2020-04-22T18:32:56.710Z INFO piecestore download started {“Piece ID”: “4HWWMJLZH3CWLI7LEGHYNWRTLK4SWFG3ZRQUSS2Y7F6KXGWEFV6A”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T18:33:14.528Z INFO piecestore downloaded {“Piece ID”: “4HWWMJLZH3CWLI7LEGHYNWRTLK4SWFG3ZRQUSS2Y7F6KXGWEFV6A”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T18:33:23.298Z INFO piecestore download started {“Piece ID”: “CJS2UBUL4IFWWMJCR5EACEQICTA5QIVT372ZWFFZUC5I4A3HGYRQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T18:33:40.458Z INFO piecestore downloaded {“Piece ID”: “CJS2UBUL4IFWWMJCR5EACEQICTA5QIVT372ZWFFZUC5I4A3HGYRQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T18:41:13.008Z INFO piecestore download started {“Piece ID”: “QPGCCI4O4PCXKAUCDM3Z75ZPQQUCFOPLWUZ3DCLYU5HD6DLFZKIA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T19:03:18.166Z INFO piecestore download started {“Piece ID”: “LJKL362KVXKEDIS6GQXUBU2JRABXA2H7DHYCMX6OZ5PCMBNNKFHQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T19:03:44.595Z INFO piecestore downloaded {“Piece ID”: “LJKL362KVXKEDIS6GQXUBU2JRABXA2H7DHYCMX6OZ5PCMBNNKFHQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T19:15:12.464Z INFO piecestore download started {“Piece ID”: “TXKH2KGTJFDU6ASYYXDIFHD44XN3EAL7WEQAVPKNZH5H6WGU7FCQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T19:15:34.123Z INFO piecestore downloaded {“Piece ID”: “TXKH2KGTJFDU6ASYYXDIFHD44XN3EAL7WEQAVPKNZH5H6WGU7FCQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T20:10:08.956Z INFO piecestore download started {“Piece ID”: “ARMMEDZ523WHFVSXBG7JXB3L23RJBKOJZSQWSCEWHAJJSQUALECA”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T20:10:12.738Z INFO piecestore downloaded {“Piece ID”: “ARMMEDZ523WHFVSXBG7JXB3L23RJBKOJZSQWSCEWHAJJSQUALECA”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T20:21:00.740Z INFO piecestore download started {“Piece ID”: “RL4LVSFSPZ3XBZD6FJQLNUEADIO6S43X6ZHL45TFFWJ33GFDB2FA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T20:21:12.041Z INFO piecestore downloaded {“Piece ID”: “RL4LVSFSPZ3XBZD6FJQLNUEADIO6S43X6ZHL45TFFWJ33GFDB2FA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T20:23:05.080Z INFO piecestore download started {“Piece ID”: “NVFAC5RTRJPQLZLXSF54H4ONTMVR2SFIK2LMBEF57CWOJBESIXAA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T20:23:53.781Z INFO piecestore downloaded {“Piece ID”: “NVFAC5RTRJPQLZLXSF54H4ONTMVR2SFIK2LMBEF57CWOJBESIXAA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T20:47:26.729Z INFO piecestore download started {“Piece ID”: “GAHYMBJR262NNOWOOHZ7SCT75U4A33QZ4TA3UT7SIVJXWFP2RGHA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T20:47:39.236Z INFO piecestore downloaded {“Piece ID”: “GAHYMBJR262NNOWOOHZ7SCT75U4A33QZ4TA3UT7SIVJXWFP2RGHA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T20:56:29.504Z INFO piecestore download started {“Piece ID”: “RUHBQQQWGRDAZJNJQXRQP6TXABBOQY25KD4KQYJALRZWT36TNJOA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T20:56:54.207Z INFO piecestore downloaded {“Piece ID”: “RUHBQQQWGRDAZJNJQXRQP6TXABBOQY25KD4KQYJALRZWT36TNJOA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T20:57:59.555Z INFO piecestore download started {“Piece ID”: “Y6IB4JWPBPS3A67YOX3UMERP5LTWSXEW25B6CUJTB47RY4BVKPDQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T20:58:02.988Z INFO piecestore downloaded {“Piece ID”: “Y6IB4JWPBPS3A67YOX3UMERP5LTWSXEW25B6CUJTB47RY4BVKPDQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T21:00:52.976Z INFO piecestore download started {“Piece ID”: “UINUOSSCNBN35VJL7O6MQQIP3XZ4FZL43BHVOIVW7G76NXRDPXVQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T21:00:56.336Z INFO piecestore downloaded {“Piece ID”: “UINUOSSCNBN35VJL7O6MQQIP3XZ4FZL43BHVOIVW7G76NXRDPXVQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T21:11:43.470Z INFO piecestore download started {“Piece ID”: “56FGCSNUNI7PP5AO24PXIYH77BBHT5IDLBZ5YXYSFKDXDVCUHE2A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T21:19:04.028Z INFO piecestore download started {“Piece ID”: “SNR4QEJBD4M7AHPRZJA46Z6JKH2INYBNNOECYQGS3YXNGKEM7FGQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T21:22:19.578Z INFO piecestore download started {“Piece ID”: “6X7JB4SXEYIUSSZBPG4GJHEQW65MXRZUFOAIISIDNNUPS6RZZOFQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T21:26:33.130Z INFO piecestore download started {“Piece ID”: “YBLG6J6QKF3LSLJFSB4GO37XFBVZTJ2SYQI5G4BMPR4VSP4QCIEA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T21:26:54.329Z INFO piecestore downloaded {“Piece ID”: “YBLG6J6QKF3LSLJFSB4GO37XFBVZTJ2SYQI5G4BMPR4VSP4QCIEA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T21:30:23.363Z INFO piecestore download started {“Piece ID”: “SWVBW4HXQZ2G7ZZMKJ7LA4PDWWTG7C4MMJX5RG4VBPWQLDH4FLWA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T21:30:43.474Z INFO piecestore downloaded {“Piece ID”: “SWVBW4HXQZ2G7ZZMKJ7LA4PDWWTG7C4MMJX5RG4VBPWQLDH4FLWA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T21:31:07.739Z INFO piecestore download started {“Piece ID”: “7MK77XNCLBM2VWKLAA2DINUETCYLWFCPYZ6OKG26UDZUH65N6G3A”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T21:43:57.776Z INFO piecestore download started {“Piece ID”: “ZYW6XOLEF7MBGESTMHZUUZP2W5XLBGLTVRIUIB6FZFJGKESR3N6A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T21:44:01.581Z INFO piecestore downloaded {“Piece ID”: “ZYW6XOLEF7MBGESTMHZUUZP2W5XLBGLTVRIUIB6FZFJGKESR3N6A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T22:02:14.169Z INFO piecestore download started {“Piece ID”: “OXXPLSB4DC6FVRPEB2HXEBOAQA4PC5G5HXMOQHZH6BV2JA34LKIA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T22:02:26.877Z INFO piecestore downloaded {“Piece ID”: “OXXPLSB4DC6FVRPEB2HXEBOAQA4PC5G5HXMOQHZH6BV2JA34LKIA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T22:03:18.376Z INFO piecestore download started {“Piece ID”: “VDOILLXI7ZVXMQ5DXPJ56S5TYUFKU3RQHPWRK6BDT3F5J2QTBFCQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T22:03:26.816Z INFO piecestore downloaded {“Piece ID”: “VDOILLXI7ZVXMQ5DXPJ56S5TYUFKU3RQHPWRK6BDT3F5J2QTBFCQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T22:11:52.727Z INFO piecestore download started {“Piece ID”: “NAQWMRLMJ4FFAOUERZ4GP6DIZOYXWNZBLBCPLDV6TIDL33UZ6IAQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:12:04.752Z INFO piecestore download started {“Piece ID”: “PBRNREKAS6YV3ZZNTMTAMYNN6B7RZRSPE3IGR7IMLGUR4AVSHS6Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:12:14.901Z INFO piecestore downloaded {“Piece ID”: “PBRNREKAS6YV3ZZNTMTAMYNN6B7RZRSPE3IGR7IMLGUR4AVSHS6Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:12:19.134Z INFO piecestore downloaded {“Piece ID”: “NAQWMRLMJ4FFAOUERZ4GP6DIZOYXWNZBLBCPLDV6TIDL33UZ6IAQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:18:02.958Z INFO piecestore download started {“Piece ID”: “LWDD6VRQXDNMMFLFMNFEJVCGYGPWWRFE7PTSIYOCRH6W5GD5POPA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:18:52.644Z INFO piecestore downloaded {“Piece ID”: “LWDD6VRQXDNMMFLFMNFEJVCGYGPWWRFE7PTSIYOCRH6W5GD5POPA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:20:03.690Z INFO piecestore download started {“Piece ID”: “IGA5H5Z2GO45CF3GQUR6B7UHM5GV4NDCVGQ5HVQMS6OHA2KRMISQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T22:20:26.169Z INFO piecestore downloaded {“Piece ID”: “IGA5H5Z2GO45CF3GQUR6B7UHM5GV4NDCVGQ5HVQMS6OHA2KRMISQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T22:27:46.352Z INFO piecestore download started {“Piece ID”: “HN3FRN57LAMW3NBVN5SO6WDSLA4NFY53PPMVORNDW45DURVVWM5A”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T22:29:20.192Z INFO piecestore download started {“Piece ID”: “WXAOSGFP6L3J2IRZPTKQQG7KTTIGTLSJVNECLWMUZQQ7VLDQK4AA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:33:21.728Z INFO piecestore download started {“Piece ID”: “RSFMO6JDXLK6ON63K6IWVKXHTBIAMFBARC4QKBGCY65EQMEFQNIA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T22:43:07.628Z INFO piecestore download started {“Piece ID”: “NETQDUKZKCBAXHZMLJ56CZMBP7BUOP4HEPJTHF5F6XIRBMFWXIMA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T22:43:20.193Z INFO piecestore downloaded {“Piece ID”: “NETQDUKZKCBAXHZMLJ56CZMBP7BUOP4HEPJTHF5F6XIRBMFWXIMA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T22:44:09.027Z INFO piecestore download started {“Piece ID”: “6XCWU73Z3T3LR4NISKPCTXFTJBIYSC5MGLQM6FMP7WDRJG3OUJYQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:44:19.658Z INFO piecestore downloaded {“Piece ID”: “6XCWU73Z3T3LR4NISKPCTXFTJBIYSC5MGLQM6FMP7WDRJG3OUJYQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:49:49.979Z INFO piecestore download started {“Piece ID”: “6FZGCNLZWWB7MC3D2NIOGPEQCJHWC4BQLEFV7MEQQY6PKMVANSGQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:50:33.252Z INFO piecestore download started {“Piece ID”: “MTVJCATYB46C2UNLPQLJWAGWZMA3OPJULKGKUVHIJBDLLDH4VY3A”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T22:52:55.897Z INFO piecestore download started {“Piece ID”: “MJI6B5L2A2GA3TG3ZAP3HDDXOJ3SBA6KVUPZRYLFCBQR27KRLLQQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T23:00:22.352Z INFO piecestore download started {“Piece ID”: “3TCYUOKDTGNQDN5JHBP7MOVIH6PLKVKDJAD34YIMZILSDA3VXKBQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T23:08:23.028Z INFO piecestore download started {“Piece ID”: “XB2HQUFGGBHUOHBMTYY4PS5FMVF5UMEGGOW45XVPGDTMYAHUHS3Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:08:37.618Z INFO piecestore downloaded {“Piece ID”: “XB2HQUFGGBHUOHBMTYY4PS5FMVF5UMEGGOW45XVPGDTMYAHUHS3Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:08:45.710Z INFO piecestore download started {“Piece ID”: “3652GGE4UBB5POWYSQH3XIUU76ZAC46ZE3C4JETWNA4NWMPZ6H5A”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:09:00.186Z INFO piecestore downloaded {“Piece ID”: “3652GGE4UBB5POWYSQH3XIUU76ZAC46ZE3C4JETWNA4NWMPZ6H5A”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:09:09.628Z INFO piecestore download started {“Piece ID”: “KCUJXYP6SGST6C2W5GHOX26QEUHFWDEKCZTOQOM7UHNTBLLNZAHQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:09:30.311Z INFO piecestore downloaded {“Piece ID”: “KCUJXYP6SGST6C2W5GHOX26QEUHFWDEKCZTOQOM7UHNTBLLNZAHQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:12:06.954Z INFO piecestore download started {“Piece ID”: “H6KULI6GYZ7XFDAX2XHQB7RLYGCEJHWJX43EDRM7ZGEQIG3CUMTA”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T23:14:26.300Z INFO piecestore download started {“Piece ID”: “CMPQ63KEFPDTGOPIFUJKQIZX5F7TF46O6UH6SYZL454NTJVX2TAQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T23:15:05.689Z INFO piecestore download started {“Piece ID”: “4USEKJAZ345FRNNYQ4BQPKHP66TGZOQUBMX63GYRFXY4MMZBQAXA”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T23:34:53.998Z INFO piecestore download started {“Piece ID”: “A3EXE52SVLCFZAI5QLMWOD2WE2L7WAL2D4OIJ7BJ6KM35ZGN2ZHQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T23:34:59.326Z INFO piecestore downloaded {“Piece ID”: “A3EXE52SVLCFZAI5QLMWOD2WE2L7WAL2D4OIJ7BJ6KM35ZGN2ZHQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-22T23:38:14.600Z INFO piecestore download started {“Piece ID”: “FQJ6BZH3AYBMBDXMGVXZYR4R4IPS7LDZMNK423OBZ5KICYERBSXA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:38:16.661Z INFO piecestore downloaded {“Piece ID”: “FQJ6BZH3AYBMBDXMGVXZYR4R4IPS7LDZMNK423OBZ5KICYERBSXA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:38:29.141Z INFO piecestore download started {“Piece ID”: “ZZ3ZMIZM62N2G2BBHJXASZ4B3WZE3DSPG4VL4Q6PHB7EUBSPDJRA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T23:38:35.069Z INFO piecestore downloaded {“Piece ID”: “ZZ3ZMIZM62N2G2BBHJXASZ4B3WZE3DSPG4VL4Q6PHB7EUBSPDJRA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-22T23:51:15.656Z INFO piecestore download started {“Piece ID”: “PTXYUIX5DRE6KPCJTKDLZCWEJ3JHW52QRCBJDBGQEVI7KDLOUJDA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_AUDIT”}
2020-04-22T23:52:50.045Z INFO piecestore download started {“Piece ID”: “6IYM5ELP6BP553VZTHDYEHDL35PU63JSQII5D2KFTAYMBNG7IC4A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T23:53:02.267Z INFO piecestore downloaded {“Piece ID”: “6IYM5ELP6BP553VZTHDYEHDL35PU63JSQII5D2KFTAYMBNG7IC4A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T23:57:57.187Z INFO piecestore download started {“Piece ID”: “EOWJOLQMV7L252YAUZQUFTCUCYJ7LIU5ORVZJMLLQQ57PV7LMA2Q”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_AUDIT”}
2020-04-22T23:58:31.211Z INFO piecestore download started {“Piece ID”: “CBIGOCS7XWZBL2PQAE7GCXH2VXL66LYOHO3JK2WBMRCZDEXJPISA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_AUDIT”}
2020-04-22T23:58:32.685Z INFO piecestore downloaded {“Piece ID”: “EOWJOLQMV7L252YAUZQUFTCUCYJ7LIU5ORVZJMLLQQ57PV7LMA2Q”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_AUDIT”}
2020-04-22T23:59:34.137Z INFO piecestore download started {“Piece ID”: “ANFD6X6KUAWFOZH7FQMDXSCMER5VH6LCI4Y3KILUTFCSZNHDSJJQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T23:59:45.390Z INFO piecestore downloaded {“Piece ID”: “ANFD6X6KUAWFOZH7FQMDXSCMER5VH6LCI4Y3KILUTFCSZNHDSJJQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-23T00:07:47.059Z INFO piecestore download started {“Piece ID”: “INXGE3BMGAVNS2ZCIT2L7UX22OGFK2BIMBYWX2ZLOZAXNUXZXO3Q”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-23T00:07:54.804Z INFO piecestore downloaded {“Piece ID”: “INXGE3BMGAVNS2ZCIT2L7UX22OGFK2BIMBYWX2ZLOZAXNUXZXO3Q”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-23T00:21:47.227Z INFO piecestore download started {“Piece ID”: “AT5WGL7CZ4LLSDDVW3RKOX727QFF7CQRRRPKF7I3DEM6ML2Y3HXQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-23T00:29:18.651Z INFO piecestore download started {“Piece ID”: “LRMADEDAZM5KU72ZCYAB744IP326SSI7PUPWICJCPHWGUEJLASMQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-23T00:29:30.804Z INFO piecestore downloaded {“Piece ID”: “LRMADEDAZM5KU72ZCYAB744IP326SSI7PUPWICJCPHWGUEJLASMQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-23T00:31:21.928Z INFO piecestore download started {“Piece ID”: “2KJZHESODCE7V5OMV27YAF2FQBVBA2Z6UCXTVBAEAUTBRJUWF2YQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T00:32:21.125Z INFO piecestore download started {“Piece ID”: “WK64W5LUQ57CA7GUNRS62534XBFOSGYGVWMORQA7TBRIB2TUOBGA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-23T00:32:47.383Z INFO piecestore downloaded {“Piece ID”: “WK64W5LUQ57CA7GUNRS62534XBFOSGYGVWMORQA7TBRIB2TUOBGA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-23T00:35:49.135Z INFO piecestore download started {“Piece ID”: “ZG3ERTCFUIH5674BHX4YPTCZXHXRBLBSOWZY2SZ7GXMN7ZOBUSQA”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-23T00:36:42.874Z INFO piecestore download started {“Piece ID”: “K45OVOIUUHG3G4P6G5PWJGGGURHUWY6SIB6FIVSWOHXBHUFAZBFQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_AUDIT”}
2020-04-23T00:48:58.981Z INFO piecestore download started {“Piece ID”: “GNVBKOREQV7JLZ2B2OZTXSVDWYFZRDZXDIZOSIY5CEUZ5GV2STMQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_AUDIT”}
2020-04-23T00:51:41.347Z INFO piecestore download started {“Piece ID”: “KFXR3MNWIRDJSRU7LR5WODROBIRHNRP4A52ZCE2JA5N43EI4CXCQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-23T00:51:56.627Z INFO piecestore downloaded {“Piece ID”: “KFXR3MNWIRDJSRU7LR5WODROBIRHNRP4A52ZCE2JA5N43EI4CXCQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-23T00:54:45.333Z INFO piecestore download started {“Piece ID”: “57VQKNDTBW2ZNAS3LN24RYFYX3NLMSEWY5AHKWTKRKLQBB3OEKOQ”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T01:10:41.945Z INFO piecestore download started {“Piece ID”: “TC4X2OZNSFRJECONV2T3BMQJREJNQNCTDAW6RCM3P6ZTEPHLTNAQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-23T01:10:58.433Z INFO piecestore downloaded {“Piece ID”: “TC4X2OZNSFRJECONV2T3BMQJREJNQNCTDAW6RCM3P6ZTEPHLTNAQ”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-23T01:16:03.520Z INFO piecestore download started {“Piece ID”: “HIPELF7Q4KEVCDJEKYZ2J6F7QZ3SHTC3UFM3RG2EONQTR352KWMA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-23T01:16:13.137Z INFO piecestore downloaded {“Piece ID”: “HIPELF7Q4KEVCDJEKYZ2J6F7QZ3SHTC3UFM3RG2EONQTR352KWMA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-23T01:18:41.658Z INFO piecestore download started {“Piece ID”: “M4LBKVNI5UQY6Q3NGE6KZLH2RREQQ223MAQSL4CO7FRPYQ2WQDGA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T01:18:58.465Z INFO piecestore downloaded {“Piece ID”: “M4LBKVNI5UQY6Q3NGE6KZLH2RREQQ223MAQSL4CO7FRPYQ2WQDGA”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T01:25:15.628Z INFO piecestore download started {“Piece ID”: “4RDEII22MWZFIM5RAHHNWKKQDX2TCFQESLWRMOQUZACAZFAXEM5Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T01:25:16.788Z INFO piecestore downloaded {“Piece ID”: “4RDEII22MWZFIM5RAHHNWKKQDX2TCFQESLWRMOQUZACAZFAXEM5Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T01:26:21.694Z INFO piecestore download started {“Piece ID”: “BCYLI3PXHQWZ7TK7UPDIWNQLR74URMCKV2F23GX6Y3K3NKGMRZ7Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T01:26:33.311Z INFO piecestore downloaded {“Piece ID”: “BCYLI3PXHQWZ7TK7UPDIWNQLR74URMCKV2F23GX6Y3K3NKGMRZ7Q”, “Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “Action”: “GET_AUDIT”}
2020-04-23T01:28:41.229Z INFO piecestore download started {“Piece ID”: “H7OHW5URHPIBAJYKNZRENR7BP6OAL2SK6BGJ5JZ3MM767TAWKI5Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-23T01:28:56.841Z INFO piecestore download started {“Piece ID”: “AEM3UZSNMUNABY3PB2TOVX7H7KAJPS3DR6FUQZ4FWCAAQQCQHAOA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET_AUDIT”}
Your Storage Node on the us-central-1 Satellite was suspended. You were suspended on 2020-04-22 at 21:11 UTC.
Your Storage Node on the asia-east-1 Satellite was suspended. You were suspended on 2020-04-22 at 22:31 UTC.
Your Storage Node on the europe-west-1 Satellite was suspended. You were suspended on 2020-04-22 at 23:51 UTC.
Hey @Alexey
Thanks for the welcome. I’ve noticed a lot of your work in these forums. Thanks for all of your effort!
I’ve filtered my logs by satellite during each timeframe below. I don’t see anything that seems bad. What am I missing?
Your Storage Node on the asia-east-1 Satellite was suspended. You were suspended on 2020-04-22 at 22:50 UTC.
2020-04-22T22:50:35.370Z INFO piecestore download started {“Piece ID”: “PJ7YUCBAANDJ77BMM7GN5SEUVEFXGFJOS3KN2ZGLYSS3ZHWSKH5Q”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”}
2020-04-22T22:50:45.428Z INFO piecestore download started {“Piece ID”: “ZFOXSBNNMH3VSQXAJYMSUOIZKP56IVNJ3CWTK3TLADJ4CYTFY7AQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET_AUDIT”}
2020-04-22T22:50:46.322Z INFO piecestore download started {“Piece ID”: “NYB533AXAZGAW7PLVOX5Z5JWBOYEUTP322DOOWAJC2S33SLINKPA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”}
2020-04-22T22:50:54.590Z INFO piecestore download started {“Piece ID”: “KLZRGVG6NWZJFFXNIAVABNLD3CWAZWHZLCFZE37TOXEIU5YBCCRQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”
Your Storage Node on the us-central-1 Satellite was suspended. You were suspended on 2020-04-22 at 21:38 UTC.
2020-04-22T21:38:03.529Z INFO piecestore download started {“Piece ID”: “FISOZ22FDPYY6HQEPCPVZVWZVIKKS2YC3DR4QN4UCRJLL4PUDNBA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET”}
2020-04-22T21:38:20.803Z INFO piecestore download started {“Piece ID”: “YZGNLIO3YCBR35D36HIXTEJQ6FVRITBKMWAVNWVRKIDWWQKQB32A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET”}
2020-04-22T21:38:31.275Z INFO piecestore download started {“Piece ID”: “NG3T4HHBSBZ74LO75ZZJOL4CUUUZPN2DAPTN6EM3JG7OWQIHPI2Q”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET”}
2020-04-22T21:38:46.323Z INFO piecestore download started {“Piece ID”: “GKQSLF6DAZFHB72NZ7CXRUOG5GWSD7WD55EPWOBB5PKWXHZFNP4Q”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET”}
@littleskunk @Alexey
Finally had some time to look at logs. ZERO errors. 100.00% audits, looks like I am still getting traffic up/down. I think the new automated emails were tripping false positives. Am I really suspended?
Node ID: 12UzxJS8iFiYuL7AqpSE7tmjkp8B4aCNopjNZ5yrQP3TBymgCzc
Your Storage Node on the us-central-1 Satellite was suspended. You were suspended on 2020-04-23 at 00:07 UTC.
2020-04-23T00:06:37.797Z INFO piecestore upload started {“Piece ID”: “WFPCQILTCDUNCCWMOWGQWLH43LSJVKKTRDK5SG7P33FYWCX5RBHQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364063257728}
2020-04-23T00:06:38.098Z INFO piecestore upload canceled {“Piece ID”: “JXNYVR6CG6Z3UV7H3EBKABGQPRQJQH22GCDC2XA44FM2FUHLYS4Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T00:06:38.307Z INFO piecestore upload canceled {“Piece ID”: “NCK7XYJRBC24Q4EHIVGHAI34WE7UQHLLVYRT7TZPZPMEN6NKSPIQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T00:06:38.350Z INFO piecestore upload started {“Piece ID”: “EZOMPQNQUOMP2I54I7UPMP4A6AC54MPWZYVCJMN3IHMSTTVI46WQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364061955968}
2020-04-23T00:06:38.393Z INFO piecestore upload started {“Piece ID”: “TKJWGTRQIK2DQPCMUL73SHVTMJAAME5OE7IDJUHV7LJM35VYMP3Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364061955968}
2020-04-23T00:06:38.601Z INFO bandwidth Performing bandwidth usage rollups
2020-04-23T00:06:38.880Z INFO version running on version v1.1.1
2020-04-23T00:06:41.082Z INFO piecestore download started {“Piece ID”: “CN5JAXP77EGJL2X6PU735C276ZSSGQ7ILG7YIZXSUK33AYJ2JNBA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:06:42.016Z INFO piecestore download started {“Piece ID”: “AAMCATGFCY6ZPYQSFIQMR5DD2I3NFDH44DFLPWNOOEN3VYKFG4CQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:06:42.750Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “NZPIIXIFAFN3SLADFR2S24YUSMEJR7OZED4ZZZFP2BCQVVNCNIIQ”}
2020-04-23T00:06:42.770Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “6AERHVMXZV2GG5NHZA5PMKQWTYGDJF43HGZNUAIIZSYY5PLJAMSQ”}
2020-04-23T00:06:42.835Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “APPOAXZOFI2S4LAXREX5GCOQLNB2ILKTPR73TRXHCWLOHX2MYN6Q”}
2020-04-23T00:06:45.351Z INFO piecestore downloaded {“Piece ID”: “TPF35XMPFIMJPCSXMQADSFRJQN345EYZAZUMQOLNDXEJ7RMWGXCA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET”}
2020-04-23T00:06:45.396Z INFO piecestore upload canceled {“Piece ID”: “WFPCQILTCDUNCCWMOWGQWLH43LSJVKKTRDK5SG7P33FYWCX5RBHQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T00:06:45.448Z INFO piecestore uploaded {“Piece ID”: “EZOMPQNQUOMP2I54I7UPMP4A6AC54MPWZYVCJMN3IHMSTTVI46WQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T00:06:45.528Z INFO piecestore upload canceled {“Piece ID”: “BV64KZ6JR2LDTUV3T62WKRW3NCZQ77H4NPJZ3WVH3QSM45BN7GHA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
2020-04-23T00:06:45.590Z INFO piecestore uploaded {“Piece ID”: “BMGJ56H3OQIT2FHUSMMNFMN5A2PBTSJDF3FERGSY7FPSIII6WQ2Q”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”}
2020-04-23T00:06:45.592Z INFO piecestore uploaded {“Piece ID”: “JFWQLSTEZTD25X35O4ZHEGFA7YDEAI745YFCXJVKJMR6Q2JD4YIQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T00:06:45.673Z INFO piecestore uploaded {“Piece ID”: “TKJWGTRQIK2DQPCMUL73SHVTMJAAME5OE7IDJUHV7LJM35VYMP3Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”}
2020-04-23T00:06:47.487Z INFO piecestore download started {“Piece ID”: “5VYTDWZR543B2E7R54JH6HPTEO3VLWVFATD3OIA22C2WBKEJ5NHA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:06:49.239Z INFO piecestore download started {“Piece ID”: “RMHBR3SOGGU7ZRHFFFJUH55TGQWWG4634P64S7DU45QX5WKBJ5ZA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”}
2020-04-23T00:06:50.275Z INFO piecestore deleted {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Piece ID”: “6P53ULHX2IKASBN5NCUD3P53IH5DNUKRWNR54455R4H23WE6UPDQ”}
2020-04-23T00:06:50.893Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “TVGLXUMM76VX6TGIGMTXIMHKBXX4KD62EE25V3WFSJIV2QDPUQ3Q”}
2020-04-23T00:06:50.996Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “UQ7JEA4W7GAM3ZQVCVGT3LI2IATFKGHMKA4ZKGB42AN45USPUHIA”}
2020-04-23T00:06:51.023Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “4UJ5CWOUFVDYS4XSNDHI7VPMJHCOKFJNRGLBP6QDNHK2QI7XQSSQ”}
2020-04-23T00:06:51.729Z INFO piecestore download started {“Piece ID”: “HSJFG4ALU5N4CK626ZZ4VKKYTMISRATE5FR5LJUAAZ3PZC6DP2NQ”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET_REPAIR”}
2020-04-23T00:06:56.127Z INFO piecestore download started {“Piece ID”: “KPJFXDAB2OEXAZ5YXC3V57QZINKKGLZV735ELJHCWPG2WT4ZFTSA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”}
2020-04-23T00:06:56.601Z INFO piecestore download started {“Piece ID”: “7CE7PWAS6I7OO5VL47KGJFVXDQCXQGYRUDXFW65BJ6XXOA6F4QOA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”}
2020-04-23T00:06:57.818Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “IHHT2N7XUGVNFMIUX7DCQOPSZTGAWDPDL3SYXAJJCES7HCN5QUXA”}
2020-04-23T00:06:57.944Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “32KCNWNVHQUISGHS6YS44ATS6KCOFSTOCDK2EWLEZ4IWMBM5M75A”}
2020-04-23T00:06:58.036Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “JZDDQJWDQ3LTCKYSKONLT464ZWEDZXI3XP3YEUP5O2ELR7GGPFRQ”}
2020-04-23T00:07:02.260Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “COJXOWMMQDBOUYJXX54HLUULQJK4SUKW3PPM5NCMQLTDVESFDC2A”}
2020-04-23T00:07:02.689Z INFO piecestore download started {“Piece ID”: “AEWGRE2PDTTARJQ3RBCQWSMKZ4GBUM7PKDWI53GXYKAKIAWS4EEQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”}
2020-04-23T00:07:05.632Z INFO piecestore download started {“Piece ID”: “P36YJKK6XZIGKHXJOAMQ64DERUFWGG52L6XWSZOSHWKILASXR5SA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-23T00:07:07.621Z INFO piecestore download started {“Piece ID”: “GSFBBDN4FJYORVLQEMDBB4SLYTEUHSFGB7RFARYLGKCE4DADEL7A”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”}
2020-04-23T00:07:09.674Z INFO piecestore download started {“Piece ID”: “ZA72D7PM66SVW25Q7JVZ4FQKLNV6YIFNFJ2OYEQ4ZRBPY5HGNXSA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:10.018Z INFO piecestore download started {“Piece ID”: “6FU53XTVHUU6MQO5Q7FZRW4AMQOI6WIL33CEWCGTFHC4YB7V3SPA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”}
2020-04-23T00:07:14.327Z INFO piecestore download started {“Piece ID”: “ZWHQ6U476H6UWNJWDG66Y2WYZIEA6OWGODONDFDF7PYKNZWYLYQQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”}
2020-04-23T00:07:17.486Z INFO piecestore deleted {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Piece ID”: “LP64WFOICOR6JB6MKQPJI7UD75SMIQXOKP6P3XLE4Z3OPUQ5UZDA”}
2020-04-23T00:07:25.906Z INFO piecestore deleted {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Piece ID”: “SXJMDS67KEW6VM7T4ZVAZ4QM2YP2SF5VADKIGA7MV4SOJQRMHBUA”}
2020-04-23T00:07:26.165Z INFO piecestore download started {“Piece ID”: “FW6VYP7OJJE7J722AC6JNTOEGJPQ32UMJAUQNR7QBVEV5DJGTEBQ”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”}
2020-04-23T00:07:26.495Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {“count”: 18}
2020-04-23T00:07:26.495Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {“count”: 1173}
2020-04-23T00:07:26.495Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {“count”: 4858}
2020-04-23T00:07:26.495Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW sending {“count”: 258}
2020-04-23T00:07:26.495Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {“count”: 859}
2020-04-23T00:07:26.495Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {“count”: 582}
2020-04-23T00:07:27.049Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB finished
2020-04-23T00:07:27.342Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S finished
2020-04-23T00:07:29.471Z INFO piecestore download started {“Piece ID”: “72VIV7PHTDCUHPKM7UYUUJE6ZS75BQSPFQHP6JK46TR5CAGM4D2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET”}
2020-04-23T00:07:30.864Z INFO piecestore download started {“Piece ID”: “RDPEK5H2R346BVHSEMF425SGHQITIT64HKWBWJEHWT3CBFJQLSVQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:31.555Z INFO piecestore download started {“Piece ID”: “AVXLTGGNDRPWFAVW3QILAGOBWK3LRH5XVAJNZ6LHR44YPAC5Z4VA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “GET”}
2020-04-23T00:07:33.319Z INFO piecestore download started {“Piece ID”: “XH77UEMSIDF5JER26EDSTBVUGB6D2MLXOUT32Y55QL34X4G4QM4A”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:35.352Z INFO piecestore download started {“Piece ID”: “CPUYFAUI76T522SILOXYBMM6GX34QV6K2HFSVYU7RHYU2J5DXIEQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:35.968Z INFO piecestore deleted {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Piece ID”: “7N3RKRKVLP5ZLYW2BRYYHBQA6HYOZDPCRNUISQAG7M6YB6MQNZRA”}
2020-04-23T00:07:37.133Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “PV4BJQAUQUJQSA357JLJFMU2QJSIU3GIIVDGROMFI6SVAB2QMX7A”}
2020-04-23T00:07:37.240Z INFO piecestore download started {“Piece ID”: “G6IMGVCU7PB3VEWKJNUV6XSPWH3D7F2IW7IUSJL4QLYJULZXCGHA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:39.404Z INFO piecestore download started {“Piece ID”: “PANVZ33OHEA56DIHV67B2S4ZFHGNIXSO3QD44ROVAVJ3YQQWJ56Q”, “Satellite ID”: “118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW”, “Action”: “GET”}
2020-04-23T00:07:39.667Z INFO orders.118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW finished
2020-04-23T00:07:40.171Z INFO piecestore deleted {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Piece ID”: “4E2VU37ZXDGE3FLX6QDFNFFXUIQRRK2XJZDYLZ2IIUGIO5AKP6QA”}
2020-04-23T00:07:47.180Z INFO piecestore download started {“Piece ID”: “ZISWMDP7T65DVAI6XZ6H5YD773EFIPCS34UXZFRROC2SEEKOPGVQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:48.439Z INFO piecestore download started {“Piece ID”: “LL5K6PAN3XDAT4NZX2KXMMHMTRTCSIYSCP4LH6WRFADGEQAWMYBQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:52.292Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs finished
2020-04-23T00:07:52.337Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 finished
2020-04-23T00:07:54.622Z INFO piecestore upload started {“Piece ID”: “S5YRV6XODB27C2BJO4RZF2VW5Z4LL3Z7JP5NLXQ436DKA3OXJIKQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364082860928}
2020-04-23T00:07:54.786Z INFO piecestore upload started {“Piece ID”: “6OSUH5VEA6KG7VLRXAHYGX6AOQ7JDGUCMOOUUAFSZCL2SNEJPYUA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364082860928}
2020-04-23T00:07:54.869Z INFO piecestore upload started {“Piece ID”: “QGYB2XUL6XXY7KG3VC3OEFMURU7PMEWGYFINLR3C54U4M3VU3YUQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364082860928}
2020-04-23T00:07:54.907Z INFO piecestore upload started {“Piece ID”: “T5J4QOSYVHKBAQDG5TW7XNKT5DVXK5DGCB5SOVGCQXNYKZNAVPDQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364082860928}
2020-04-23T00:07:55.039Z INFO piecestore upload started {“Piece ID”: “VCG4YQ2MFSENMN5GW4AYFY3BTJEIZ2ZGC6UZNUW5CMXPY7LV3M2Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364082860928}
2020-04-23T00:07:55.166Z INFO piecestore upload started {“Piece ID”: “YKCWG5XVK43UEBZV54FTVGDCNAVYUHPBUZKOPRLVUCJOLUURYVDQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364082860928}
2020-04-23T00:07:55.179Z INFO piecestore upload started {“Piece ID”: “XH3RI6VLGIJRGIFVQOSTL3DY235QGNNAABYV6YE2DGHROQRB2SEQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364082860928}
2020-04-23T00:07:55.662Z INFO piecestore upload started {“Piece ID”: “F7VEJRFMYDGIWHWMTF73X5YIQIC2LQOQZM7NU3L75PIW5NK3QKJA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364080541056}
2020-04-23T00:07:55.757Z INFO piecestore upload started {“Piece ID”: “BJ5F4KPGMUTNRAINQJNCQ2TC7XFJMIFXKLM36O5FXNAZA5E3H43Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364078221184}
2020-04-23T00:07:55.780Z INFO piecestore upload started {“Piece ID”: “CS4GTFOHJK4ALJ66EFSUA6DYYQI2V5HFP5PPFLYG3JFMQSMRAYBA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364078221184}
2020-04-23T00:07:55.974Z INFO piecestore upload started {“Piece ID”: “JBZTXUK2P3YZ6TOCD6D2XLXHNSI4MKP23K72QF6IXWQDSTQCHXUA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364075901312}
2020-04-23T00:07:56.128Z INFO piecestore upload started {“Piece ID”: “D66ETAV2YU6PMABTWX3AHGN2T6FRFZFU4V35MMOC4SH3OFGBMHJA”, “Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “Action”: “PUT”, “Available Space”: 1364071261568}
2020-04-23T00:07:56.212Z INFO piecestore upload started {“Piece ID”: “DRFLPGPCXHV2JZ7ODRUO6RGGRVMBNJ55L3A7WACHC5V3NM25X7SA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364071261568}
2020-04-23T00:07:56.388Z INFO piecestore download started {“Piece ID”: “TR2OZCFHJJWDUSU75CXKS4K2H63EQH5X6U5FFCU2J2XO5ZENWERA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “GET”}
2020-04-23T00:07:56.532Z INFO piecestore upload started {“Piece ID”: “2SE2JGUL7GKQYWTXWFK62JJOIR7QVUQUHBSQN6EO2VDDCF4UMNEA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364066621824}
2020-04-23T00:07:56.668Z INFO piecestore upload started {“Piece ID”: “HCRT5AIOI3SQUMF7ORSPK3VCMS7IAUCCASGE7AZVI53FWZ7YEWJA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364066621824}
2020-04-23T00:07:56.804Z INFO piecestore upload started {“Piece ID”: “AEXWEEDRG5TVBGBNKUZRYSETVPQQPXXWYZXULMZFE7DP6VH6TH5A”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364064301952}
2020-04-23T00:07:57.061Z INFO piecestore upload started {“Piece ID”: “HBCDLOJD5OJBDHGNPEWSAREML5ASJ3BZIZY3W442BTMLHZPYOFLQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364064301952}
2020-04-23T00:07:57.227Z INFO piecestore upload started {“Piece ID”: “MAMO5JORFGXH7ZBFA4R2APIC4V5AUKRUIHN227JG5HL6M6D2TSXQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364059662208}
2020-04-23T00:07:57.559Z INFO piecestore upload started {“Piece ID”: “PLKTIGL372FPIQL6H4NLSU3PRZMGYJCMLLMR3VADXQCOIK625RDQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364055022464}
2020-04-23T00:07:58.292Z INFO piecestore upload started {“Piece ID”: “LVWF5YKOXWK7XUWFCDR6RVKI63JG2ZTF7YJQDNFHEMVX6BI2B2OA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364050382720}
2020-04-23T00:07:58.646Z INFO piecestore upload started {“Piece ID”: “D5DE2MBX7SS745BQF5VP2CACRG6R2IV2UBRFON5QHCYM4K7WE2CQ”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Available Space”: 1364048062848}
2020-04-23T00:07:59.059Z INFO piecestore upload started {“Piece ID”: “MVURTDBP4RP3VBYLKBLRXHPTQE7L4MAHNE6QZY3A4SRNYW6F6W5Q”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364045742976}
2020-04-23T00:07:59.680Z INFO piecestore upload started {“Piece ID”: “TTFFJ2BXRLP4NV5K6ESEBVUAVHMCBV7BCQ2JC6KHF2MRNHDUM5RA”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “PUT”, “Available Space”: 1364045742976}
" Your Storage Node on the us-central-1 Satellite was suspended. You were suspended on 2020-04-22 at 21:59 UTC."
for sat in `docker exec -i storagenode wget -qO - localhost:14002/api/sno | jq .satellites[].id -r`; do docker exec -i storagenode wget -qO - localhost:14002/api/sno/satellite/$sat | jq .id,.audit; done
"12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"
  "totalCount": 73425,
  "successCount": 73229,
  "alpha": 19.99999999999995,
  "beta": 0,
  "score": 1
Does this have anything to do with it?
2020-04-22T21:59:24.261Z ERROR piecestore upload rejected, too many requests {“live requests”: 42}
2020-04-22T21:59:24.679Z INFO piecestore download started {“Piece ID”: “YEVJJ75IFLUODNYZZSW5W2NQSKMM6RAQNYTJVIAG3NHPG5FBYW3A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET_AUDIT”}
2020-04-22T21:59:24.804Z ERROR piecestore upload rejected, too many requests {“live requests”: 43}
2020-04-22T21:59:25.047Z ERROR piecestore upload rejected, too many requests {“live requests”: 43}
2020-04-22T21:59:25.241Z ERROR piecestore upload rejected, too many requests {“live requests”: 42}
2020-04-22T21:59:26.357Z INFO piecestore download canceled {“Piece ID”: “GGKYUMT2ALMTBKL5Q7Z4VZFJSM7GX5IZLLQHS5YMY67DZRMC6Y7A”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “GET”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doDownload.func5:646\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
Continuing to filter the log @Alexey, I am seeing “out of space” errors from the us-central-1 satellite on a PUT action on 4/22. I’m running a 6TB volume with 5.4TB used (on file system stats). STORJ Dashboard shows 5.1TB used with 413.8 GB avail. I believe my docker start command indicated 5.5 TB. (Full disclosure: the last time I download/restarted the container within the last 1-2 weeks, I entered 7.5TB erroneously. Some time later, I corrected it back to 5.5 TB)
I don’t see those errors on asia-east-1 but I do see many GET errors on “write TCP”, “use of closed network connection”
I gotta stop for the night. Since correcting a couple of issues related to CPU and maybe some network issues. @Alexey, I think all of my previous errors are gone except occasional “failed to add order”. I see gets on both satellites that previously suspended me but I’m not seeing any PUTs from them. Will look forward to hearing from you tomorrow… and it will likely be tomorrow night before I can catch up on health and/or continue troubleshooting. THANKS, refined.
I followed this blog post and looks like this is the error for my node get suspended,
docker logs --since 2020-04-22T23:56:00Z storagenode
Its same time when everyone else has got this emails.
Error:
upload canceled {“Piece ID”: “7ROYBV2GEAW4S4YZFESPG4HUQLPSTXWWRAWUVIZVN63H54TYOIXA”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “error”: “context canceled”, “errorVerbose”: “context canceled\n\tstorj.io/common/pb/pbgrpc.init.0.func3:70\n\tstorj.io/common/rpc/rpcstatus.Wrap:77\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:452\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:215\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:987\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:107\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:105\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:56\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:93\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51”}
I have tried multiple restarts. Recreating contaiers Nothing seems to work. Checked audit and nothing wrong with it all good and healthy numbers as others have posted here.
I don’t understand this error. It would be nice if someone can help identify this issue.
Also I am stuck on 1.1.1 versioin using docker image storagenode storjlabs/storagenode:beta. I tried to use storagenode storjlabs/storagenode but didn;t worked so fall back to beta image.
Let me know if you guys have any solution but to me looks like sorj devs are overwhlmed by this queries. Not enough man power for all of SNO’s. I understand I am dev too support is always the hardest part.
Only sad part is my reputation damage after running node without errors for so long.
Thanks.
I got suspension warning for Europe satellite, I have audit score of 99.8% on it, but it has been at 99.8% for months iirc.
I stopped receiving data yesterday because I used up all the alotted space, went to -5GB.
I did have downtime for maintenance yesterday but node always had access to data.
How do I check logs on FreeBSD?
